1. Replace backspace by the conjugate operator. 2. Plot: conserve points/lines, remove others ...add Smath 3D, Maxima X_Y ,,, maybe plotG(,) 3. The range Summation is desirable 4. The vector Sum is desirable. 5. Undefined integrator is desirable 6. 'n' derivative is desirable. 7. if/else, if/otherwise [some maths don't accept if/otherwise] ============================================== 8. Insert Image 9. Insert Writer region 10. Insert Area/Separator Few more work sheet functionalities ? 1. Shift, click on sparse regions to select 2. 3. Enhancing Smath is another story.
