Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything? Matrix -Insert Row or Column.sm (6kb) downloaded 45 time(s).Edited by user 12 April 2018 20:24:20(UTC)
Cutrrently not possible: [ SS-13] |
Thank you Just added a vote to this item
Originally Posted by: ElSid Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ... Simply => submatrix !
Originally Posted by: ElSid Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ... ================ simply submatrix !
Was thanked: 21 time(s) in 17 post(s)
Jean, Sometimes your convoluted solutions really do inspire ... when I understand them Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (7kb) downloaded 46 time(s).Thank you
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion, reserved for Fourier 'ifft'... why did you remove it. For common work, rater use InsertCol/InsertRow. RS_Insert cols_rows to Matrices(1).sm (48kb) downloaded 50 time(s).
