Offline Vijay
#1 Posted : 08 May 2018 20:24:06(UTC)
Vijay
Rank: Member
Hi All,
I have created an equation and waveforms. I was trying to integrate the waveform but am not getting the expected answer.
The period of the waveform is 0.0166 sec. the expected answer is 0.300 A
I am attaching HWRL.sm (12kb) downloaded 24 time(s). the file HWRL.sm (12kb) downloaded 20 time(s).
Vijay
#2 Posted : 09 May 2018 05:44:33(UTC)
1. adjust the period from the tentative attached.
2. The integrator is a scalar integrator, but you have a discrete set.
3. If you want to know the area under the curve,
then use finite differences method in two segments.
HWRL[1].sm (14kb) downloaded 26 time(s).
Similar Topics
Integration accurate at(3) (Samples)
by Jean Giraud 26/08/2023 20:12:10(UTC)
Integration Trapeze (Samples)
by Jean Giraud 17/05/2023 19:58:03(UTC)
Simpson versus Trapezoidal method used for integration (Samples)
by Javier Ochoa 16/05/2023 16:51:42(UTC)
Integration Advanced Tool Box (Samples)
by Jean Giraud 22/02/2023 00:40:51(UTC)
CNC Center Machine can be said to be the integration of machine functions (Bugs & Problems)
by h513n182 13/05/2022 11:05:57(UTC)
Integration Triple [simplex] (Samples)
by Jean Giraud 16/02/2022 18:03:50(UTC)
Integration Utilities PART 1 (Samples)
by Jean Giraud 13/02/2022 18:51:06(UTC)
INTEGRATION Voltera 2nd Kind (Samples)
by Jean Giraud 15/10/2021 15:56:30(UTC)
INTEGRATION over path (Samples)
by Jean Giraud 10/05/2021 15:26:26(UTC)
integration with FreeCAD and Blender (Feature Requests)
by jtm2020hyo 05/04/2021 04:50:52(UTC)
How to get integration value in range (Questions)
by netsonicyxf 30/01/2021 17:19:03(UTC)
Integration not solving - No real roots (Questions)
by davidlimtw 21/01/2021 20:32:02(UTC)
Integration Area Under A Line / Curve (Questions)
by davidlimtw 11/01/2021 22:34:00(UTC)
Integration Difficult (Samples)
by Jean Giraud 19/10/2020 18:28:30(UTC)
Integration [20200610] (Samples)
by Jean Giraud 10/06/2020 15:58:18(UTC)
