Offline yuriy1996
#1 Posted : 17 May 2018 15:31:49(UTC)
yuriy1996
Rank: Member
Ukraine
I need to recreate the formula for determining the minimum protective layer of concrete. In the formula there is a choice of the maximum value in curly brackets. How do I use this program to make the minimum protective layer of concrete equal to the maximum value in a curly bracket and greater than or equal to 10 millimeters.
c_min=max{c_min,b;c_min,dur+c_dur,y-c_dur,st-c_dur,add}>=10 mm
Offline ElSid
#2 Posted : 17 May 2018 15:59:08(UTC)
ElSid
United States
Please attach your sheet
Offline PompelmoTell
#3 Posted : 17 May 2018 16:25:12(UTC)
PompelmoTell
In fact, it would be advisable to send the sample sheet. Something is not convincing (the braces in Smath are not used). However, the "max" function provides for evaluating the maximum value of a vector internally; then you can put in a vector all the elements to choose the maximum (including "10mm"Wink. Alternatively, the "Max" function contained in the "Custom" plugin (you have to install it from a special menu) directly accepts the lists.
Offline yuriy1996
#4 Posted : 17 May 2018 17:14:53(UTC)
yuriy1996
Rank: Member
Ukraine
Zakhisnijj shar betonu.sm (5kb) downloaded 21 time(s).
Offline yuriy1996
#5 Posted : 17 May 2018 17:17:41(UTC)
yuriy1996
Rank: Member
Ukraine
#6 Posted : 17 May 2018 17:37:43(UTC)
PompelmoTell
Zakhisnijj_shar_betonu.sm (6kb) downloaded 40 time(s).
thanks 2 users thanked PompelmoTell for this useful post.
on 17/05/2018(UTC),  on 17/05/2018(UTC)
#7 Posted : 18 May 2018 00:50:10(UTC)
Min/Max ... for Matrices/Vectors
min/max ... for functions in matrices/vectors
Sample attached to illustrate min(vector of functions)
2D Plot Discontinuous [min(,)].sm (15kb) downloaded 52 time(s).
