SMath Studio Forum
Questions
[Maxima Plugin] is a custom Maxima function call-able in SMath
Joined: 22/05/2018(UTC) Posts: 25 Location: California
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated. Attached are the Maxima .mac file and the SMath file attempting to call it. func_gradient_divergence_curl.7z (1kb) downloaded 48 time(s). calling custom Maxima function.sm (5kb) downloaded 64 time(s).Edited by moderator 22 May 2018 13:21:45(UTC)
| Reason: added Maxima tag
Originally Posted by: 007.000 Any help would be appreciated. Forget what does not work outside of native Smath Maths Grad_Div_Curl.sm (13kb) downloaded 49 time(s).
... Jacob.sm (54kb) downloaded 42 time(s).
Joined: 15/04/2012(UTC) Posts: 1,985 Was thanked: 1124 time(s) in 721 post(s)
Originally Posted by: 007.000 I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated. Attached are the Maxima .mac file and the SMath file attempting to call it. func_gradient_divergence_curl.7z (1kb) downloaded 48 time(s). calling custom Maxima function.sm (5kb) downloaded 64 time(s). It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup. |
SMath Studio Forum
Questions
