Offline 007.000
#1 Posted : 22 May 2018 12:13:20(UTC)
007.000
Rank: Member
United States
Although lcm() works in Maxima... it won't work for me in Smath using Maxima(lcm())
I'm a noob but researched for hours and am non-the-wiser... Any help is much appreciated.
The only result when searching the forum is a Matlab plugin which I couldn't work... plus I'm not sure lcm() is included with that plugin anyway.
https://en.smath.info/forum/yaf_...tlab-C-Math-Library.aspx
lcm.sm (3kb) downloaded 45 time(s).
Edited by moderator 22 May 2018 13:14:53(UTC)  | Reason: added Maxima tag
#2 Posted : 22 May 2018 14:58:17(UTC)
You need to load the "functs" package in Maxima first. Seems that wxMaxima does that on startup. I could also load this package automatically if required.
You can add this locally to your maxima.xml in the plugin directory (search for this file to find the directory).
Offline 007.000
#3 Posted : 23 May 2018 10:31:44(UTC)
007.000
Rank: Member
United States
Thank you Mr. Kraska...
I found a Japanese page where others had to load it on their Maxima first as well.
http://web.sfc.keio.ac.jp/~yama/nos/?p=3505
Also this third party Maxima manual tells users to do so as well.
http://www.delorie.com/gnu/docs/maxima/maxima_95.html
Which turned out to actually be the instructions for SMath not Maxima.
Now I suppose I'll need to write a loop in order to use the function with more than two numbers.
Somewhat curious since Maxima has an ezgcd() function which accepts more than two inputs. Anyhow, I will click thanks on your profile Sir.
update: When I click thank on your post an error occurs.
Edited by user 23 May 2018 10:47:19(UTC)  | Reason: Not specified
Guest (2)
