Too many things in the same thread.
Quote:Hi Uni,
Is XY plot still being actively developed?
I was hoping you can address the image quality when printed to PDF. Source code updated, but I can't build the plugin now. EDIT: A few bugs still present, be patient. Edited by user 06 June 2018 21:15:12(UTC)
Plugin updated. Now you can check pdf quality. |
6 users thanked uni for this useful post.
on 07/06/2018(UTC), on 07/06/2018(UTC), on 07/06/2018(UTC), on 07/06/2018(UTC), on 08/06/2018(UTC), on 08/06/2018(UTC)
Originally Posted by: uni Plugin updated. Now you can check pdf quality. Woa this was some ninja-quick plugin patching!!!! thank you UNI (and Davide), all works well :-D
1 user thanked Alex M. for this useful post.
Plugin refactored and updated. Please check your documents. List1.pdf (118kb) downloaded 77 time(s). |
5 users thanked uni for this useful post.
on 16/06/2018(UTC), on 16/06/2018(UTC), on 17/06/2018(UTC), on 17/06/2018(UTC), on 18/06/2018(UTC)
Updated. Error with exceeding the maximum number fixed. remez.sm (14kb) downloaded 106 time(s). remez.pdf (49kb) downloaded 126 time(s).Edited by user 18 June 2018 20:11:42(UTC)
3 users thanked uni for this useful post.
on 18/06/2018(UTC), on 18/06/2018(UTC), on 18/06/2018(UTC)
Updated. Definition support restored. Edited by user 21 June 2018 11:43:28(UTC)
on 21/06/2018(UTC), on 21/06/2018(UTC)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Thanks Uni. It works now. |
Updated. Try now. Also shift and control keys available when zooming. Edited by user 21 June 2018 18:52:03(UTC)
on 21/06/2018(UTC), on 21/06/2018(UTC), on 23/06/2018(UTC)
Hi, this plugin is crashing on ubuntu when I click "format" in the context menu. Any clue what could be the cause?
I have this installed 4.13.0-45-generic #50~16.04.1-Ubuntu SMP Wed May 30 11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
mono-complete/xenial,now 4.2.1.102+dfsg2-7ubuntu4 amd64 [installed]
Thanks!
Updated. Tested on RaspberryPi 3. |
Is it possible to plot text at a specified coordinate in X-Y Plot Region or ZedGraph Plot? (Not in 2D Plot) |
For now there is no such possibility, but theoretically it can be added. |
Thank you uni for info. Edited by user 24 June 2018 16:53:24(UTC)
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
... and if we can overlap a label with a transparent background over the Graph to simulate a similar effect? Do not remember exactly if a label with a transparent background is possible with the Davide's plugin but I have the feeling that recently a similar feature has been added. I need to double check if it is feasible.
Franco
At present I do as follows to display text (static). Edited by user 25 June 2018 10:42:31(UTC)
