Offline omorr
#1 Posted : 08 July 2018 09:38:09(UTC)
omorr
Rank: Administration
Serbia
Try to reproduce this, please.
This is the attached file bug.sm (5kb) downloaded 19 time(s).
Now, disable the function definition
f(x) vectorized will get stuck.
#2 Posted : 08 July 2018 17:09:58(UTC)
Not a bug, very many different calculated results are stored.
That is very handy ... example: images
The "rainbow ColorMap Electron" is there as you open the work sheet.
Image Rainbow Colormap [Electron].sm (253kb) downloaded 16 time(s).
Offline PompelmoTell
#3 Posted : 08 July 2018 23:53:25(UTC)
PompelmoTell
I think Radovan just wanted to indicate a malfunction when the function is disabled and the subsequent vectorization on the function goes into an infinite loop.
I think he was expecting a non-evaluation (I was expecting it too)
thanks 1 user thanked PompelmoTell for this useful post.
on 14/07/2018(UTC)
#4 Posted : 09 July 2018 00:54:50(UTC)
It does not go into an infinite loop.
Once assigned, result of vector/matrix is resident as an identity to the project.
No matter if disabled afterwards, calculated and stored.
This feature is one of my preferred vs Mathcad.
Online ola_nicolas
#5 Posted : 09 July 2018 01:29:01(UTC)
ola_nicolas
Romania
... I think he was expecting a non-evaluation (I was expecting it too) ...
Hello
I did not think about this. That's why I decided to delete my previous message. With righteous excuses.
Nicolas.
#6 Posted : 09 July 2018 01:37:49(UTC)
Originally Posted by: ola_nicolas Go to Quoted Post
In MathCAD there are possibilities to solve some equations or systems of equations where vectorizing of functions can be applied.
Essentially, Smath vectorize operator works same as Mathcad [11 and earlier].
However, there are some nuance as Smath is not a clone of Mathcad.
Vectorizing an image over a function is gorgeous [grayscale, RGB] ...
... but there is an exception ... Explain:
Smath vectorizes a matrix over a scalar function.
linter, cinter, ainterp are NOT scalar functions.
You must then make them fake scalar via if/otherwise, exemplified in
Contour Solve [user ColorMap].
Solve TREASURY_1 [Iterate L, Lc].sm (37kb) downloaded 13 time(s).
Solve Recursive [f(x), Inverse f(x)].sm (58kb) downloaded 14 time(s).
Contour SOLVE [user ColorMap].sm (311kb) downloaded 13 time(s).
#7 Posted : 09 July 2018 05:28:25(UTC)
Originally Posted by: ola_nicolas [url=/forum/yaf_postsm50702_Vectorization-bug.aspx#post50702][/url]In MathCAD there are possibilities to solve some equations or systems of equations where vectorizing of functions can be applied.
... here is a good example of vectorizing roots..
Vectorize Examples_00.sm (17kb) downloaded 15 time(s).
#8 Posted : 09 July 2018 05:53:06(UTC)
... that's the document I missed posting :
Vectorize Examples_00.sm (17kb) downloaded 16 time(s).
Offline omorr
#9 Posted : 09 July 2018 09:00:56(UTC)
omorr
Serbia
I'll have to get back to my first post
Function f(x) was not defined. What is going on then? Why the calculation did not stop with an error issued? If you wait enough it can crash SMath. I reproduced that on few computers and suspect this might be a bug or a problem. That was my question.
#10 Posted : 09 July 2018 16:31:49(UTC)
For sure, if you wait too long before [Shift+Esc] it will crash Smath,
because it enters an infinite loop. That answers your question ! bug !
When entering an infinite loop there should be an error message/stop calculate.
Caution: if you figure you have entered an infinite loop stop,stop,stop ...
it will crash Smath and zap the document "root element missing" => 0kB
All that from true story !
You can generalize your attempt by defining algorithm style.
