#1 Posted : 11 July 2018 01:33:33(UTC)
Was thanked: 574 time(s) in 444 post(s)
Works fine.
Inst_pH Solution.sm (25kb) downloaded 12 time(s).
#2 Posted : 11 July 2018 05:36:55(UTC)
Works fine.
... refreshed, optimized calculation timing
Added the buffered plot to be splined for + values.
Inst_pH Solution.sm (45kb) downloaded 19 time(s)....refreshed/augmented
Offline omorr
#3 Posted : 11 July 2018 10:42:18(UTC)
omorr
Rank: Administration
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 285 time(s) in 244 post(s)
Hello Jean,
For me, the first plot is working
but the second is not - cases() is complaining.
I could see that sigma2 went nuts (do not know why) and put eval() in front of it
I do not have the explanation of this - might be a bug.
#4 Posted : 11 July 2018 14:09:43(UTC)
1. Can't understand the error cases(,) [6671]
2. Make unit K was first problem , done well.
3. Doctoring for the spikes works and accelerates calculation timing.
Inst_pH Solution Copy.sm (47kb) downloaded 13 time(s).
Offline ElSid
#5 Posted : 12 July 2018 01:21:14(UTC)
ElSid
United States
Was thanked: 7 time(s) in 7 post(s)
Can you explain sheet. I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
#6 Posted : 12 July 2018 05:16:55(UTC)
Originally Posted by: ElSid Go to Quoted Post
Can you explain sheet.I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
The program is a dual iterative solver.
Give some more about Langelier saturation index.
#7 Posted : 12 July 2018 05:49:28(UTC)
Langelier saturation index [LI] has nothing to do wrt unbuffered.
As it looks, there are lot of those things already tabulated.
Wait and see if you can come up with some interesting stuff.
