Is it possible to change and save the Page Setup defaults? Thanks!
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: RFreund Is it possible to change and save the Page Setup defaults? Thanks! Try this 1. Open PC 2. Open Smath. 3. Page setup as you wish 3. Save page as "Template" 4. Close Smath 5. Open Smath, Template
Jean - Thanks you are correct, that does work for new sheets. I will do this going forward.
It would be nice to set this as default as I will still need to modify old sheets, but this is a good work around for now.
Thanks again.
Originally Posted by: RFreund It would be nice to set this as default as I will still need to modify old sheets Up to version 6179, open a work sheet created "Portrait" Change setup for "Landscape", save ... it re-opens "Landscape" It also saves new borders/margins ... Try it.
