SMath Studio Forum
Samples
Statistics Hypergeometric applications
Hi Jean. Try with this Gamma. Best regards Alvaro. Stat Hypergeometric Discrete.sm (86kb) downloaded 28 time(s).PD: Also, avoid to use the same variable as limit of integration and the dummy (or "mute" integration variable.
Originally Posted by: Razonar Hi Jean. Try with this Gamma. Best regards Alvaro. Thanks Alvaro, Your algo added to the previous H.T. Davis [Abramowitz & Stegun] Jean Maths Special Gamma(x) 15D_Algos.sm (39kb) downloaded 23 time(s).
SMath Studio Forum
Samples
