I am using it everyday for my professional work. Thank you so much!
more...
by Tien Nguyen
Très bon logiciel de calcul, avec de nombreux plugin pour tous les usages.
Une fois qu'on s'habitue, on ne peut plus s'en passer.
Je le recommande vivement.
Outre les fonction mathématiques, Il est possible d'utiliser de nombreuses bibliothèques, comme par exemple la bibliothèque Coolprop pour les données thermodynamiques, ce qui permet d'avoir un outil très évolué pour faire et expliquer des calculs très rapidement.
more...
by Vidal Silva
Alternativa gratuita fantastica a MathCAD !
This is a fantastic free alternative to Mathcad, strongly recommended to anyone dealing with engineering and calculus.
more...
by Marco
on 30/10/2018(UTC), on 30/10/2018(UTC), on 30/10/2018(UTC), on 31/10/2018(UTC), on 01/11/2018(UTC)
Sometimes I test new versions of Smath with my very old worksheet which keeps failing since 0.98.5973. This time it puzzled me again. Please see how it performs now. The SS prints the result of maple(expand(...)) normally, but after assigning the resulting expression to the variable nnn, it failed even to display nnn. What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s).Edited by user 01 November 2018 03:29:59(UTC)
Originally Posted by: tomtit Sometimes I test new versions of Smath with my very old worksheet Maybe just like this Tom ... like 5346, 6179
Originally Posted by: tomtit ... What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s). Hi. It means that can't recalculate because the use of sums and products. For force the recalculation as it is needed, can enclose the num definition by a line: Best regards. Alvaro.
