2 Pages12>
Offline qanniu
#1 Posted : 08 November 2009 16:18:25(UTC)
qanniu
hi ,i'm just find smath today.i want to know is there some function like dec2bin or hex2bin...smath can you tell me thanks.
Offline Andrey Ivashov
#2 Posted : 09 November 2009 04:53:16(UTC)
Rank: Administration
Was thanked: 2006 time(s) in 677 post(s)
No. Program have no these functions, but they will be implemented.
Offline qanniu
#3 Posted : 09 November 2009 06:35:21(UTC)
qanniu
thanks,hehe.i'was finding the function all the days yesterday.by the way ,it is morning in China.
Offline marks2c
#4 Posted : 27 December 2022 03:40:39(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
Epic dredge sorry. Functional, with all credit to @Razonar (source/author).
20221227 Dec2bin.sm (5kb) downloaded 14 time(s).
Also needed:
* set string length (ie leading zeros), and
* functions for bit field testing.
Edited by user 27 December 2022 04:33:05(UTC)  | Reason: Crediting source
#5 Posted : 27 December 2022 23:14:06(UTC)
Was thanked: 983 time(s) in 811 post(s)
Thanks, nice source code.
algo(col) was designed to recover matrix col(s) string(s) to values.
Cheers ... Jean.
Maths Convert-dec2bin.sm (19kb) downloaded 13 time(s).
Offline marks2c
#6 Posted : 28 December 2022 00:19:56(UTC)
marks2c
New Zealand
The source was repurposed from Razonar.
Interesting, thanks Jean.
Do you know a way to implement a fixed 9-bit binary counter in SMath (or display a decimal counter in fixed-length binary)? This is probably a bit too esoteric to be a feature request...
Edited by user 28 December 2022 00:33:13(UTC)  | Reason: Not specified
#7 Posted : 29 December 2022 16:46:20(UTC)
Sorry Collab: I have no idea yet how to counts pulse.
From recollection, such demand was not honored.
Cheers ... Jean.
Offline overlord
#8 Posted : 29 December 2022 17:50:13(UTC)
Turkey
Was thanked: 544 time(s) in 366 post(s)
If I understood correctly;
You want a 9bit binary representation similar to 8084 cpu registers.
I must admit it is a highly specific request.
registers
#9 Posted : 29 December 2022 19:07:13(UTC)
That comes easily ... ?
Offline marks2c
#10 Posted : 29 December 2022 21:04:28(UTC)
marks2c
New Zealand
Thanks Jean, greatly appreciated.
I should have been more clear in my request.
I'm after a 9-bit long bit-field count that I can test each bit (ie each bit has a 2^n position in the whole count) so that as the count progresses. This way each of the 9 tests will have been performed half the tests in the 0 branch and half in the 1 branch.
If it is 0 then do x, otherwise do y type of thing.
The application is worst-case circuit analysis: https://k6jca.blogspot.c...-worst-case-circuit.html
Half the tests with the +% tolerance applied the other half with the -ve tolerance applied.
Edited by user 29 December 2022 21:24:05(UTC)  | Reason: Not specified
Offline marks2c
#11 Posted : 29 December 2022 21:12:34(UTC)
marks2c
New Zealand
registers
Very close, thanks overloard.
I'm after an asynchronous 9-bit ripple-style counter that I can bit-test (or equivalent) 9 times during each loop, each time to do one of two actions half the time (ie calculated with each extreme of the tolerance) for worst-case circuit analysis.
This may be better achieved via dec2bin() with a constant 9-bit length output so that the 2^n check work consistently (ie string position tests).
FYI (reference only): https://k6jca.blogspot.c...worst-case-circuit.html. The need is for X-Y style visualization that LTSpice can't provide.
Edited by user 29 December 2022 21:26:27(UTC)  | Reason: Not specified
Offline Razonar
#12 Posted : 29 December 2022 21:39:13(UTC)
Razonar
Uruguay
Was thanked: 974 time(s) in 609 post(s)
Hi. Something like this?
bin_counter.sm (10kb) downloaded 8 time(s).
on 29/12/2022(UTC)
Offline marks2c
#13 Posted : 29 December 2022 21:40:56(UTC)
marks2c
New Zealand
Modification of Razonar's dec2bin() should work well.
dec2bin(p,q) where p is the bit-field length and q is the decimal number to be converted.
Check the converted string's length and then pad the front with zeros to suit.
Offline marks2c
#14 Posted : 29 December 2022 21:44:09(UTC)
marks2c
New Zealand
Cripes Alvaro. Good to see your 'calibrated-crystal-ball' and 'mind-reading skills' are as good as your awesome maths/coding skills!
Offline overlord
#15 Posted : 30 December 2022 02:46:04(UTC)
Turkey
Maybe this can be useful.
dec2bin.sm (4kb) downloaded 8 time(s).
on 30/12/2022(UTC)
Offline marks2c
#16 Posted : 30 December 2022 03:04:15(UTC)
marks2c
New Zealand
Perfect! Thank you overlord
Offline marks2c
#17 Posted : 30 December 2022 05:03:42(UTC)
marks2c
New Zealand
I spoke too soon! Bit-testing don't work so well on a string.
A much better idea is a column vector with each of the 9 (ie n#) elements being either a one or a zero.
Edited by user 30 December 2022 05:09:13(UTC)  | Reason: Not specified
Offline overlord
#18 Posted : 30 December 2022 11:09:06(UTC)
Turkey
This was what I coded first, after that I made it to string.
Here is what you have asked for.
dec2bin.sm (7kb) downloaded 9 time(s).
on 30/12/2022(UTC)
Offline marks2c
#19 Posted : 30 December 2022 12:39:01(UTC)
marks2c
New Zealand
Thank you so much overlord, that is both elegant and perfect!
#20 Posted : 30 December 2022 17:05:26(UTC)
Maybe, that's what you are looking for ?
Maths Convert num2str EXTENDED.sm (7kb) downloaded 9 time(s).
2 Pages12>
