2 Pages12>
Offline OchkovVF
#1 Posted : 05 December 2023 18:53:18(UTC)
OchkovVF
Was thanked: 38 time(s) in 36 post(s)
Pendulum.sm (234kb) downloaded 9 time(s).
Online uni
#2 Posted : 05 December 2023 19:38:18(UTC)
uni
Was thanked: 1285 time(s) in 750 post(s)
Ctrl+Shift+K.
Russia ☭ forever
Viacheslav N. Mezentsev
on 05/12/2023(UTC)
Offline OchkovVF
#3 Posted : 06 December 2023 04:44:09(UTC)
OchkovVF
Originally Posted by: uni Go to Quoted Post
Ctrl+Shift+K.
Can we solve this task with SMath + Mathcad
Online uni
#4 Posted : 06 December 2023 06:05:11(UTC)
uni
Можно попробовать, если будет доступен оригинальный документ Mathcad.
Russia ☭ forever
Offline OchkovVF
#5 Posted : 06 December 2023 06:55:01(UTC)
OchkovVF
Pendulum-Spring.xmcd (160kb) downloaded 8 time(s).
#6 Posted : 06 December 2023 09:09:08(UTC)
Was thanked: 1145 time(s) in 736 post(s)
The definition of l(t) must be inside or above the Mathcad block
Federpendel-block.sm (40kb) downloaded 13 time(s).
on 06/12/2023(UTC)
Offline OchkovVF
#7 Posted : 06 December 2023 11:04:43(UTC)
OchkovVF
My solution
Pendulum-Spring.xmcd (83kb) downloaded 4 time(s).
Offline OchkovVF
#8 Posted : 06 December 2023 11:15:14(UTC)
OchkovVF
Animation needed
#9 Posted : 06 December 2023 13:57:07(UTC)
Was thanked: 983 time(s) in 811 post(s)
Simple pendulum + animation.
ODE Pendulum Copy.sm (104kb) downloaded 4 time(s).
Offline Razonar
#10 Posted : 06 December 2023 18:49:26(UTC)
Razonar
Uruguay
Was thanked: 857 time(s) in 543 post(s)
Comparing with the usual elastic pendulum.
Click to enlarge
Ochkov elastic pendulum.sm (33kb) downloaded 12 time(s).
thanks 2 users thanked Razonar for this useful post.
on 06/12/2023(UTC),  on 06/12/2023(UTC)
Offline OchkovVF
#11 Posted : 06 December 2023 20:38:55(UTC)
OchkovVF
See please the Fig. 4.10 here
http://twt.mpei.ac.ru/oc...V-F-Engineering-Calc.pdf
Now I would like to rewrite this Russian-English book with SMath. Help me please!
Edited by user 06 December 2023 20:43:22(UTC)  | Reason: Not specified
Offline OchkovVF
#12 Posted : 07 December 2023 02:02:42(UTC)
OchkovVF
Why I have an error in this task? Help please!
Pund-Spring.sm (16kb) downloaded 4 time(s).
Offline OchkovVF
#13 Posted : 07 December 2023 03:27:58(UTC)
OchkovVF
More simple task
Pund.sm (12kb) downloaded 3 time(s).
#14 Posted : 07 December 2023 12:47:42(UTC)
If F(t) is requested as result, you have to specify F'(t). k(F) is the tangential stiffness of the spring, the inverse of the tangential compliance.
Federpendel-NL.sm (14kb) downloaded 10 time(s).
Edited by user 07 December 2023 12:50:19(UTC)  | Reason: Not specified
on 07/12/2023(UTC),  on 07/12/2023(UTC)
Offline OchkovVF
#15 Posted : 07 December 2023 19:03:36(UTC)
OchkovVF
More animations
https://community.ptc.co...rm-with-shue/td-p/635149
Let create it with SMath
Слабо?
Edited by user 07 December 2023 19:32:19(UTC)  | Reason: Not specified
#16 Posted : 07 December 2023 21:59:36(UTC)
In this version you can specify the initial force in the spring. The initial conditions for x and y are adjusted appropriately.
Federpendel-NL.sm (16kb) downloaded 12 time(s).
on 08/12/2023(UTC),  on 08/12/2023(UTC)
#17 Posted : 08 December 2023 09:12:47(UTC)
Your Mathcad Given/Odesolve ... solves via Maple.
Verhulst solves wrt limits ... pretty advanced.
Inst_Verhulst.sm (28kb) downloaded 3 time(s).
on 08/12/2023(UTC)
Offline Razonar
#18 Posted : 08 December 2023 11:06:15(UTC)
Razonar
Uruguay
The equations of motion, using Lagrange dynamics, from this post:
ElasticPendulum.sm (245kb) downloaded 8 time(s).
Edited by user 08 December 2023 11:16:00(UTC)  | Reason: Not specified
on 08/12/2023(UTC),  on 09/12/2023(UTC)
Offline Razonar
#19 Posted : 08 December 2023 13:54:19(UTC)
Razonar
Uruguay
In this version you can specify the initial force in the spring. The initial conditions for x and y are adjusted appropriately. ...
A comparison between Martin's solution and that given by the equations of motion obtained from the Lagrangian. Spoiler: both give the same result.
I'd like to point out how incredibly complicated this problem actually is, and what a series of brilliant implementations Martin makes. For example, where the hell does he get the time derivative of the force on an elastic bar when he is given only the length of the bar as a function of the force? Obviously, it is not enough to apply the theorem of the derivative of the inverse function, but you also have to have a deep knowledge of the mechanics of the system to remember something called tangential stiffness, and although it uses k to represent it, we forgive it because It's German and they are well known to use their own abbreviations. Well, actually I don't know what letter to use, because I don't remember ever using that magnitude for any practical purpose, but in Spanish literature it is quite common to use k for its inverse, which is the constant that appears in Hooke's law. Or at least I think so, because the existence of elastic bodies is actually a complication, they should all be rigid better.
Another notable thing about this example is that I would like someone to please explain to me how the hell the Viacheslav plugin manages to handle l'(t) within the equations, because I honestly didn't expect it.
Federpendel-NL - Lagrangian.sm (258kb) downloaded 7 time(s).
thanks 3 users thanked Razonar for this useful post.
on 08/12/2023(UTC),  on 08/12/2023(UTC),  on 08/12/2023(UTC)
Offline OchkovVF
#20 Posted : 08 December 2023 19:00:10(UTC)
OchkovVF
Have you seen this plot
Edited by user 08 December 2023 19:11:42(UTC)  | Reason: Not specified
2 Pages12>
