Offline Prmtv
#1 Posted : 17 August 2024 06:07:15(UTC)
Prmtv
Hello!
Such a problem appeared. Please tell me what's the matter
00.sm (10kb) downloaded 8 time(s).
Thanks!
#2 Posted : 17 August 2024 11:49:32(UTC)
Was thanked: 1177 time(s) in 752 post(s)
roots() in this case needs a custom initial guess.
00_Kr.sm (14kb) downloaded 7 time(s).
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
Offline Prmtv
#3 Posted : 18 August 2024 06:20:41(UTC)
Prmtv
how to choose the right one initial guess?
Offline overlord
#4 Posted : 18 August 2024 10:15:52(UTC)
Turkey
Was thanked: 544 time(s) in 366 post(s)
What I can suggest is to use right solver.
Offline Prmtv
#5 Posted : 19 August 2024 01:25:46(UTC)
Prmtv
how is the order of output of variables determined? From function "Unknowns"?
Offline overlord
#6 Posted : 19 August 2024 01:51:08(UTC)
Turkey
how is the order of output of variables determined? From function "Unknowns"?[/attach]
My guess and and experience is they are ordered alphabetically.
Offline Prmtv
#7 Posted : 23 August 2024 05:23:22(UTC)
Prmtv
Thanks!
But when creating exe-file required variables a, b, B, t = 1. Why does this happen? Or is this a feature of the plugin "Nonlinear solvers"?
Offline overlord
#8 Posted : 23 August 2024 06:05:06(UTC)
Turkey
I can't know what you have done without your sheet.
However, this was not an issue when I saved it as an exe.
Offline Prmtv
#9 Posted : 23 August 2024 09:42:01(UTC)
Prmtv
If I use the function "al_nleqsolve" then everything really works
The problem occurs when using the function "FindRoot"
Offline overlord
#10 Posted : 23 August 2024 10:11:17(UTC)
Turkey
It is due to some bug or miscode for FindRoot().
Or this is totally SMath result parse method.
Your solution (A) is stored symbolic.
Make it totally numeric by eval().
Exe file can show correct results after that.
Offline Prmtv
#11 Posted : 26 August 2024 07:33:45(UTC)
Prmtv
Thanks!
