SMath Studio Forum
Questions
problem with solving a system of equations
Hello! Such a problem appeared. Please tell me what's the matter  00.sm (10kb) downloaded 8 time(s).Thanks!
Joined: 15/04/2012(UTC) Posts: 2,046  Was thanked: 1177 time(s) in 752 post(s)
roots() in this case needs a custom initial guess. 00_Kr.sm (14kb) downloaded 7 time(s).![2024-08-17 00_46_56-SMath Solver - [00.sm_].png](/forum/resource.ashx?a=49619&b=2) |
how to choose the right one initial guess?
Joined: 23/07/2013(UTC) Posts: 1,191  Was thanked: 544 time(s) in 366 post(s)
Originally Posted by: Prmtv  how to choose the right one initial guess? What I can suggest is to use right solver.
how is the order of output of variables determined? From function "Unknowns"?
Originally Posted by: Prmtv  how is the order of output of variables determined? From function "Unknowns"?[/attach] My guess and and experience is they are ordered alphabetically.
Thanks! But when creating exe-file required variables a, b, B, t = 1. Why does this happen? Or is this a feature of the plugin "Nonlinear solvers"?
I can't know what you have done without your sheet. However, this was not an issue when I saved it as an exe. Regards
Originally Posted by: overlord  I can't know what you have done without your sheet. However, this was not an issue when I saved it as an exe. Regards  If I use the function "al_nleqsolve" then everything really works The problem occurs when using the function "FindRoot"
It is due to some bug or miscode for FindRoot(). Or this is totally SMath result parse method. Your solution (A) is stored symbolic. Make it totally numeric by eval(). Exe file can show correct results after that. Regards
Originally Posted by: overlord  It is due to some bug or miscode for FindRoot(). Or this is totally SMath result parse method. Your solution (A) is stored symbolic. Make it totally numeric by eval(). Exe file can show correct results after that. Regards  Thanks!
SMath Studio Forum
Questions
