Hello, I need to calculate 2 successive integrals in order to obtain the deflection of a beam with variable depth
To derive algebraically the integral is too tough for me.
The in-built integral in Smath doesn't work twice (We can integrate a function only once) and Andrey has explained in the forum that it is a limitation of this in-built feature.
I did the following:
1) define the beam depth D(x) as a function of x
2) calculate the beam inertia I(x)=D(x)^3/12 x width
3) define the bending moment M(x) as a function of x (textbook formula)
4) calculate the second derivative of the deflection by the formula: D2(x)=M(x)/I(x)/E (E is the elastic modulus)
5) calculate the slope function, D1(x) by integration of D2(x) using Smath Studio in-built feature
6) digitise the slope function over a number of points: I obtain 2 vectors, X and Y
7) define the slope function slope(x) using linterp(X,Y,x) built-in feature
8) find the deflection function D(x) by integration of the digitised slope function slope(x)
My worksheet is extremely slow. 50 points take 10 minutes or so.
Then I tried a second process, digitising every step right from the beginning. This is quicker but it still takes 1 minute for 50 points.
I find this problem puzzling because when I integrate twice another function, like sin(x), also using the same digitised process right from the beginning, it can calculate 500 points in 1 second!
This looks like I am not able to "decouple" the digitised function from the original one, as if Smath was still calculating everything from the beginning, passing through the "digitisation barrier"...
I am attaching 2 files, the one with the fully digitised integration process for the cantilever beam with variable depth, and the one with the same process applied on a simple sin(x) function.
I feel there must be a way to make this work. I need this deflection calculation for calculating rammed earth piers under seismic action.
Any advice would be welcome!
Thanks
Laurent
deflection of a cantilever with variable depth.sm (29kb) downloaded 8 time(s).
digitizing and integrating a.sm (34kb) downloaded 3 time(s).
