Joined: 22/02/2023(UTC) Posts: 39 Location: Seoul Was thanked: 1 time(s) in 1 post(s)
he first formula calculated well. The second formula did not calculate. The result is "The stack is empty." What is the problem? stack_is_empty.sm (9kb) downloaded 2 time(s).
Joined: 23/07/2013(UTC) Posts: 1,173 Was thanked: 534 time(s) in 358 post(s)
Either clear R or use a different variable name, R.1 for example. Because you defined R at upper calculation, it confuses solvers. Regards
