Hello! 1) Why is the result of the sum not 0? 2) Why do different sum options differ (red from blue)? sum.sm (16kb) downloaded 3 time(s).
Joined: 23/07/2013(UTC) Posts: 1,173 Was thanked: 534 time(s) in 358 post(s)
That number practically means zero to programming languages. Decimal numbers stored in smath as fractions. In each iteration a small decimal part can be leftover. When they are collected it makes result away from zero. Putting an eval() to your calculation makes your results even smaller. Changing exponent threshold to bigger makes your results zero by the way. Regards
Originally Posted by: overlord That number practically means zero to programming languages. Decimal numbers stored in smath as fractions. In each iteration a small decimal part can be leftover. When they are collected it makes result away from zero. Putting an eval() to your calculation makes your results even smaller. Changing exponent threshold to bigger makes your results zero by the way. Regards With further calculations, the program will perceive it like 0 or will an error accumulate?
