10 Pages«<8910
Online uni
#181 Posted : 27 October 2024 02:25:46(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Coming soon...
The ability to explicitly specify the placement of block elements will be added.
It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Edited by user 27 October 2024 02:32:33(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Offline Razonar
#182 Posted : 27 October 2024 15:34:21(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Originally Posted by: uni Go to Quoted Post
... It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Hi. That's the Mathematica default notation for pure function's arguments: https://reference.wolfra...rkWithPureFunctions.html
on 27/10/2024(UTC)
Online uni
#183 Posted : 13 November 2024 09:47:53(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- fixed image handling functions (READRGB(),...);
- the appearance of brackets has been changed;
- added the ability to explicitly specify an insert for MathcadBlock (##, #1, #2, ...).
mathcadblock-explicit-paste.sm (16kb) downloaded 11 time(s).
Edited by user 13 November 2024 22:12:58(UTC)  | Reason: Not specified
on 13/11/2024(UTC)
Online uni
#184 Posted : 13 November 2024 22:42:40(UTC)
uni
Expanding the idea of ​​numbering, we can add syntax:
## - take all as sys|mat|line
#i#j - take from i to j
##j - take from 1 to j
#i# - take from i to end
and
#i#js - sys(#i,..,#j)
#i#jm - mat(#i,..,#j)
#i#jl - line(#i,..,#j)
#i#jfun - fun(#i,..,#j)
or
### - insert as parameters: foo(x,y,###) -> foo(x,y,#1,#2,...)
##3# - insert as parameters: foo(x,y,##3#) -> foo(x,y,#1,#2,#3)
#185 Posted : 14 November 2024 05:20:14(UTC)
Was thanked: 1177 time(s) in 752 post(s)
I encountered a plot problem with the list version of rkfixed(). Probably this also applies to other ODE-integrators with embedded function assignment.
In the native 2D Plot:
- When plotting a solution function along with a matrix of marker points, then the points won't display
- Yet, when using lspline() directly, both objects plot without problems.
In X-Y Plot:
- When the independent variable has the same name as the solution function (e.g. x(x), then x() is not treated as a function but as the expression x (similar with v(v) or any other name).
- A workaround is to use a variable name different from the function name. Yet this is strange, because in SMath x() and x usually are independent objects.
plotproblem.sm (31kb) downloaded 5 time(s).
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
on 14/11/2024(UTC)
Offline Razonar
#186 Posted : 14 November 2024 07:45:31(UTC)
Razonar
Uruguay
A little step further? (And I say little because I'm not the one who has to improve the code) Take #arg as function parameter?
on 14/11/2024(UTC)
Online uni
#187 Posted : 15 November 2024 09:34:05(UTC)
uni
Plugin updated.
Changes:
- MathcadBlock: the syntax for explicit insertion has been extended.
Edited by user 15 November 2024 09:42:56(UTC)  | Reason: Not specified
on 16/11/2024(UTC)
Online uni
#188 Posted : 15 November 2024 11:14:39(UTC)
uni
Crazy
mathcadblock-alnleqsolve.sm (13kb) downloaded 9 time(s).
Edited by user 15 November 2024 11:17:14(UTC)  | Reason: Not specified
on 16/11/2024(UTC)
#189 Posted : 15 November 2024 22:11:09(UTC)
Visualization of transformations and matrix norms using implicit plots and automatic scaling of the X-Y plots.
Matrixnormen 2D.sm (29kb) downloaded 11 time(s).
thanks 3 users thanked mkraska for this useful post.
on 15/11/2024(UTC),  on 15/11/2024(UTC),  on 16/11/2024(UTC)
Online uni
#190 Posted : 12 December 2024 10:09:39(UTC)
uni
I want to add a set of simple examples to the Mathcad block context menu that demonstrate how it works. Can you suggest such examples?
Similar to the X-Y Plot component. In this case, you will be able to fill in not only the input values, but also the description. You can insert arbitrary expressions inside the component.
Imagine that you can formalize the solution to a simple problem. What would you suggest as educational examples?
Edited by user 12 December 2024 10:16:51(UTC)  | Reason: Not specified
on 14/12/2024(UTC)
Offline Razonar
#191 Posted : 13 December 2024 23:18:46(UTC)
Razonar
Uruguay
I suggest a handbook like Martin's one, with examples where the user can reuse the code (Code reusability is the technical expression for when you don't want to say that you are going to copy and paste). Or like Mathcad quicksheets. This is my idea of a clean use of the block for solving high school problems.
BasicHandbook-nsol.pdf (353kb) downloaded 12 time(s).
BasicHandbook-nsol.sm (328kb) downloaded 5 time(s).
thanks 5 users thanked Razonar for this useful post.
on 14/12/2024(UTC),  on 14/12/2024(UTC),  on 14/12/2024(UTC),  on 14/12/2024(UTC),  on 14/12/2024(UTC)
#192 Posted : 14 December 2024 02:06:09(UTC)
I'd like to have such things like nsol in SMath core.
How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess.
I tried to demonstrate a generic approach, i.e. you get the variables assigned without having to issue any specific command except for the generic content of the placeholder. It is just a try and fails with single variables but you get the idea.
Of course, one would like to have a solve block without the cryptic generic expression in the placeholder.
Perhaps, such a block could be created from the insert menu with pre-allocated content of the placeholder and with setting it to hidden.
BasicHandbook-nsol_Kr.sm (334kb) downloaded 8 time(s).
on 14/12/2024(UTC)
Offline Razonar
#193 Posted : 14 December 2024 04:21:36(UTC)
Razonar
Uruguay
Hi Martin. I put "0" as argument because there are no more args. The second could be a vector of options, like this:
or the solved variables. Also, I use "S" because this error, which I imagine that could be corrected, but don't know how hard it could be:
PD: Notice that x# : transpose(str2num(x#))*diag(U#) or x# : diag(U#)*str2num(x#) if you want to return the answer as column vector, like normal people, returns x# as scalar if length(x#) = 1.
Edited by user 14 December 2024 04:26:51(UTC)  | Reason: Not specified
Offline Razonar
#194 Posted : 14 December 2024 13:36:10(UTC)
Razonar
Uruguay
... How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess
Hi Martin. I think the opposite: the implicit assignment of the names of the variables sought to a solution makes its call very rigid, since many times there is no direct relationship between the variables of the equation and the names of the variables that are intended to be assigned to the solution, as is precisely demonstrated in this case
Another variant among many would be to find a limiting speed and call the result v.lim, even though the variable of the equation is "v".
Online uni
#195 Posted : 31 December 2024 06:07:50(UTC)
uni
SMath Studio compatibility History page
Mathcad Block.sm Mathcad Block. Examples.sm
Plugin updated
Changes:
- Mathcad Block: restored drawing of curly bracket (SS >= 1.3.*).
Edited by user 31 December 2024 06:18:45(UTC)  | Reason: Not specified
thanks 4 users thanked uni for this useful post.
on 31/12/2024(UTC),  on 31/12/2024(UTC),  on 01/01/2025(UTC),  on 01/01/2025(UTC)
10 Pages«<8910
