  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,640   Was thanked: 1400 time(s) in 817 post(s)
SpiceSharp (Spice#) - electronic circuit simulator
Based on SpiceSharpParser (.NET library that allows to parse SPICE netlists and to simulate them using SpiceSharp library). This plugin requires .Net Framework 4.7.2 to be installed for it to work. I managed to run the first test example on my PC. The plugin is not available on the server yet. Links: 1. SpiceSharpParser2. SpiceSharp Home PageEdited by user 23 November 2024 01:27:35(UTC)
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
For experts only. spice#.sm (6kb) downloaded 10 time(s).Plugins folder: C:\Users\User\AppData\Roaming\SMath\extensions\plugins SpiceSharp-0.1.9092.9246.zip (11,211kb) downloaded 7 time(s). |
on 22/11/2024(UTC), on 23/11/2024(UTC)
Joined: 28/08/2014(UTC) Posts: 1,509  Was thanked: 976 time(s) in 610 post(s)
I haven't even tried these features myself yet. Support for all types of analysis hasn't been tested. There's still a lot of work to do. Maybe I'll do a direct insertion of values into the circuit description. I wanted to try making a circuit with an amplitude detector. The authors have recently added the ability to specify an amplitude-modulated signal. They have a shell (GUI) in which you can also test circuits. |
Hi Viacheslav. As far as I could see, the plugin you created works very well, it just has some very minor details, like not recognizing either "u" or "μ" for micro. By the way, handling that is a configurable option in ltspice. So you shouldn't be the first one to have problems with that.
As for the analyses that spice# has, it's just a matter of discovering them, since the documentation they have is very little, and for example, I don't know what convention they followed to enumerate the nodes of the controlled sources. I took the one they use in the Qucs simulator, but there is no standard for that.
I saw the GUI for windows that you mention on github, except that they didn't compile it... or at least I didn't find it, only the source code.
Best regards. Alvaro.
 Plugin updated. Changes: - Plugin adopted to a new SMath Studio Core infrastructure; - Folders removed from the output artefacts. |
 4 users thanked uni for this useful post.
on 11/01/2025(UTC), on 11/01/2025(UTC), on 12/01/2025(UTC), on 12/01/2025(UTC)
