  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 433   Was thanked: 46 time(s) in 41 post(s)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,640   Was thanked: 1400 time(s) in 817 post(s)
Originally Posted by: OchkovVF  How can we use here a Mathcad-block? Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions. This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
Joined: 15/04/2012(UTC) Posts: 2,046  Was thanked: 1177 time(s) in 752 post(s)
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot. Here, an option of setting the aspect ratio of the axes to 1 would be good. ![2024-12-01 13_32_39-SMath Solver - [Lens-Mathcad-Block.sm_].png](/forum/resource.ashx?a=50221&b=2) Lens-Mathcad-Block_Kr.sm (53kb) downloaded 6 time(s). |
on 02/12/2024(UTC), on 03/12/2024(UTC)
Mathcad Prime    Edited by user 07 December 2024 19:09:50(UTC)
Joined: 04/10/2024(UTC) Posts: 79  Was thanked: 2 time(s) in 2 post(s)
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
Originally Posted by: Cornel  I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow? Not yet, but will be soon! Question - why is the answer meters squared, and not just meters?
Originally Posted by: Cornel  I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow? What's wrong with the existing solvers? |
Originally Posted by: uni  Originally Posted by: Cornel  I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow? What's wrong with the existing solvers? Because odesolve in Mathcad Prime: 1. Do not require to rewrite the differential equation of a higher order into a system of first order odes 2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver 3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq) What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)? Edited by user 08 December 2024 09:59:54(UTC)
Joined: 28/08/2014(UTC) Posts: 1,510  Was thanked: 976 time(s) in 610 post(s)
Best regards. Alvaro. Edited by user 08 December 2024 11:13:42(UTC)
Originally Posted by: OchkovVF  Hi. dsol can solve it with this setup:  RKA-Lens.sm (180kb) downloaded 7 time(s).I also use the Martin's setup for the plot. Best regards. Alvaro. Edited by user 08 December 2024 15:21:37(UTC)
on 10/12/2024(UTC), on 10/12/2024(UTC)
Thanks! The last step
Hi. The screen. I also simplify a little the calculations. spherical aberration.sm (27kb) downloaded 10 time(s). Best regards. Alvaro.
 3 users thanked Razonar for this useful post.
on 11/12/2024(UTC), on 11/12/2024(UTC), on 11/12/2024(UTC)
Joined: 10/12/2009(UTC) Posts: 289   Location: Cali, Colombia Was thanked: 124 time(s) in 83 post(s)
Originally Posted by: Razonar  Very elegant solution
 1 user thanked oscampo for this useful post.
Originally Posted by: oscampo  Very elegant solution Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do. Best regards. Alvaro.
on 13/12/2024(UTC), on 13/12/2024(UTC)
