Joined: 23/12/2012(UTC) Posts: 94  Was thanked: 171 time(s) in 134 post(s)
When I have already loaded an application in SMath and I want to load another application, the last one is always loaded as a new page and not as a new instance of SMath.
Sometimes (only), I want that the new application to be loaded in a new instance of SMath instead of a new page. How could I handle this option.
The reason for my demand is based on the intention of being able to run two or more applications on different screens of the same computer.
Thank you for your attention, Ioan
Do to others as you would like them to do to you! Knowledge is of no value unless you put it into practice - Chekhov |
Joined: 26/07/2022(UTC) Posts: 48  Location: UK Was thanked: 31 time(s) in 27 post(s)
Just start another instance of SMath first, then load the other application in that.
 1 user thanked StvMath for this useful post.
Joined: 20/11/2016(UTC) Posts: 10   Location: Bogota Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: StvMath  Just start another instance of SMath first, then load the other application in that. I normally don't start two instances of the application because when closing one of the instances an error is generated in the images inserted with the ImageRegion plugin of the instance that remains open.     I hope you can fix this. Edited by user 10 September 2024 15:52:39(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,728   Location: Italy Was thanked: 1396 time(s) in 910 post(s)
Originally Posted by: MauroMen  I normally don't start two instances of the application because when closing one of the instances an error is generated in the images inserted with the ImageRegion plugin of the instance that remains open. I've found where is the issue, I can fix it. Edited by user 10 September 2024 21:55:58(UTC)
Originally Posted by: Davide Carpi  I've found where is the issue, I can fix it. Fixed. Seems that the Release manager doesn't work currently, so the plugin can't be updated, but the code is uploaded in the SVN. The temporary folder that contains the images generated on the fly by the plugin now has a sub-folder for each instance of the program, therefore the issue shouldn't arise anymore (BTW probably it was already reported before). Edited by user 11 September 2024 00:50:23(UTC)
on 11/09/2024(UTC), on 11/09/2024(UTC)
Originally Posted by: Davide Carpi  Originally Posted by: Davide Carpi  I've found where is the issue, I can fix it. Fixed. Seems that the Release manager doesn't work currently, so the plugin can't be updated, but the code is uploaded in the SVN. The temporary folder that contains the images generated on the fly by the plugin now has a sub-folder for each instance of the program, therefore the issue shouldn't arise anymore (BTW probably it was already reported before). Plugin updated |
 3 users thanked Davide Carpi for this useful post.
on 11/01/2025(UTC), on 11/01/2025(UTC), on 12/01/2025(UTC)
