Offline Salazar
#1 Posted : 21 October 2009 00:30:56(UTC)
Salazar
I would highly appreciate if this program was able to run on Mac OS X. Are there any plans for this? I am a new user so I wouldn't really know the direction this project is going.
Offline LordMike
#2 Posted : 24 October 2009 03:33:22(UTC)
LordMike
As it is a .Net application, it all depends on the .Net implementation on OS X.
A project I assume will pull strings, would be Mono. (Download here).
I don't know how to run it on OS X. But in Linux, you run the command "mono appname.exe". In OS X I assume some handler will appear (Running all files of a specific extension as, equivalent in Windows).
Try it, report back :P
Offline Andrey Ivashov
#3 Posted : 24 October 2009 05:03:48(UTC)
Rank: Administration
Was thanked: 2011 time(s) in 679 post(s)
True.
I've tried to run SMath Studio on MAC OS X 10.5.4 using Mono 2.0 some time ago, but had no success. Mono for this OS has some inconsistencies, as I understood. But, maybe for last releases of Mac OS X and Mono this problems are not actual - try this.
Offline Salazar
#4 Posted : 25 October 2009 11:31:24(UTC)
Salazar
So I used mono to open Smath on Mac OS X Snow Leopard and it worked fine. It seem to lag a bit in opening the program, but once it opened, it was functioning well. Good
Offline LordMike
#5 Posted : 25 October 2009 17:36:33(UTC)
LordMike
The beauty of .Net. Anything that runs Mono, will also run .Net apps Good
#6 Posted : 25 October 2009 19:51:44(UTC)
Great news! Salazar, may I ask you to make screnshot(s) of running SMath Studio on Mac OS X like those represented on the SMath Studio download page? I will put it with the other pictures. And it will be useful for other users if you will provide numbers of versions of OS and Mono.
Thank you for the information.
Offline josh
#7 Posted : 12 March 2010 05:38:33(UTC)
josh
здесь как оно под маком бегает
тулбары кривые у нее под маком и перерисовка окна страдает сильно
#8 Posted : 12 March 2010 07:31:53(UTC)
Мда... есть над чем поработать. Большое спасибо за видео, в одной из линукс сборок наблюдал такой же высоченный тулбар и падение при печати, думал, что встретил уникальную ситуацию. Теперь очевидно, что стоит вернуться к этой сборке и решить проблему раз и навсегда!
Offline josh
#9 Posted : 24 March 2010 23:13:16(UTC)
josh
Да там и не только с тулбаром проблема, там с перерисовкой окна какие то проблемы тоже, при перемещении не обновляется сразу, только если подергать...
Offline garidan
#10 Posted : 24 April 2013 05:28:37(UTC)
garidan
I just tried installing latest mono release (2.10) and smath ( 0.95.4594) (and OSX 10.8.3 and x windows installed using homebrew) but got an error on startup.
Perhaps is it only a matter of testing ?
mono ./SMathStudio_Desktop.exe
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
at System.Drawing.Drawing2D.LinearGradientBrush..ctor (Rectangle rect, Color color1, Color color2, LinearGradientMode linearGradientMode) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Drawing2D.LinearGradientBrush:.ctor (System.Drawing.Rectangle,System.Drawing.Color,System.Drawing.Color,System.Drawing.Drawing2D.LinearGradientMode)
at System.Windows.Forms.ToolStripProfessionalRenderer.OnRenderToolStripPanelBackground (System.Windows.Forms.ToolStripPanelRenderEventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripRenderer.DrawToolStripPanelBackground (System.Windows.Forms.ToolStripPanelRenderEventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ToolStripPanel.OnPaintBackground (System.Windows.Forms.PaintEventArgs e) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Offline kilele
#11 Posted : 24 April 2013 12:39:55(UTC)
kilele
Was thanked: 133 time(s) in 114 post(s)
I recall having something like those errors when trying Slacko (Puppy based on Slackware repository). They did not include the library libgdiplus. You can try to install it from your repo.
Also try to update Mono searching for "mono-complete", "libmono" or "mono cil"
Edit:
I suggested the developer to provide download links of Mono compiled to run SMath, he may also want to prepare some PPA (Personal Package Archives) to install via Launchpad.
Something like what Darktable offers in their install page.
Edited by user 27 April 2013 03:33:34(UTC)  | Reason: Not specified
Offline flips
#12 Posted : 22 November 2016 01:01:41(UTC)
flips
Portugal
Was thanked: 2 time(s) in 1 post(s)
Mac os 10.12.1 (with all actualisations and brew updates) Smath mono (0.98) didn't work. Logo screen in desktop for long time after crashes.
Wine didn't work also, even installing dotnet 2.0 and gdiplus.
But PlayOnMac (4.2.10) installed and run SmathStudioDesktop.msi without any difficulty.
Marvellous project! LONG LIVE Andrey Ivashov
thanks 2 users thanked flips for this useful post.
on 24/11/2016(UTC),  on 27/11/2016(UTC)
Offline Mark Myatt
#13 Posted : 29 November 2018 14:14:37(UTC)
Mark Myatt
United Kingdom
I've been using an old version of MathCad with WINE on the Mac for a few years. It worked but was not flawless.
I have started to use SMath Studio in the Cloud. This runs well enough in Safari.
You can create a stand-alone app (still needs internet access) in a few minutes using Fluid. It's not a native MacOS app but it gets pretty close.
Offline Bowalt
#14 Posted : 24 December 2019 03:14:52(UTC)
Bowalt
Hi, I have question: Are you considering to port SMath Studio to macOS Catalina? Questions is related to the Mac Catalyst function for developers (https://developer.apple.com/mac-catalyst/) which allows to easily port iPadOS apps to macOS. And since SMath Studio is already on iOS store...
Offline Travis Lundy
#15 Posted : 09 March 2022 22:19:34(UTC)
Travis Lundy
United States
I have to admit I'm wishing more and more for a native Mac OS version of SMath now having had the Macbook Air with the M1 processor for a year and seeing Apple's roadmap moving away from Intel processors. I think Mono may have worked in the past but it will not with the ARM architecture and 32 bit SMath. My only workaround now is to pay to use Parallels with Window's ARM (bit of a resource hog for such a simple program). I can run the iPadOS version but that to me is not even an 1:1 comparison. I'm looking forward to the cloud version and maybe I can just move everyting there even though it is not extendable like the desktop version but I could make due. Would still love a standalone Mac version.
