Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,622 Was thanked: 1983 time(s) in 668 post(s)
New SMath Studio 0.78 Stable available Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book). SMath Studio Handheld on the Smartphone Quote:Controls:With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second. - With consecutive pushing of this button you can choose: "number related to the button", "symbols related to this button". To lock any variant just stop pushing this button 1 second. With consecutive pushing of this button you can choose: "plus operator", "minus operator", "multiplication operator", "division operator", "exponentiation operator", "plus/minus operator", "factorial", "vector multiplication operator". Also with this pushed button you can highlight the part of equation by using Left/Right buttons. By "clicking" on this button program will numerically calculate equation (this means "="); by pushing button more than 0,4 sec. program will symbolically calculate equation (this means "->"). Also, if the cursor located on the right of the not defined variable or not defined function this button will create a definition operator (this means ":=" ). Removing last character (Backspace). In the mathematical reference book this button means "Back". SMath Studio Handheld on the Communicator (PPC) SMath Studio Desktop on the Desktop (Windows) SMath Studio Desktop on the Desktop (Linux) Last changes - SMath Studio now supports Mathcad files to open (files with .xmcd extension)!
- Desktop: Dynamic cursor changes implemented (on the bounds of the controls, on resizing, on moving etc...);
- Added ability to Undo/Redo for the hole page instead of the separate history for every control;
- Selecting page controls with Ctrl key pressed implemented;
- Desktop: Ctrl+M (Open Insert Matrix dialog), Ctrl+E (open Insert Function dialog) and Ctrl+T (insert picture control) shortcuts added;
- To start writing a text " (quotes) button can be pressed;
- Desktop: PI constant now can be inserted with a shortcut: Ctrl+Shift+P;
- Desktop: Added ability to Zoom graphs by mouse wheel;
- Desktop: added Drag & Drop ability to open files from the outside;
- Desktop: Window params now save on programe close (such as: size and location);
- Improved simplification of the functions ln(x) and lg(x) in case of the x-numbers are equal e (for ln) or 10^c (for lg);
- Trigonometric functions with standard values in deg. now can be simplified;
- Min required numbers changed from 10e-12 to 10e-99;
- Fixed error with Plot control: sometimes it can't be resized.
- sec() and cosec() [csc()] functions simplification ability added;
- Numeric library improved to exclude some calculating errors;
- identity(), matrix(), rows(), cols(), el(), length(), tr() functions implemented into symbolic library;
- Vector multiplication (cross product) operator added to symbolic library for native support;
- Loops (for, while) performance improved;
- All symbolic calculations results now displays all fractional powers as radicals;
- German interface translation updated;
- Fixed error: calculation results not updates after using Undo/Redo functionality;
- Handheld: Fixed error with various matrix Toolbar button modes on non-cyrillic devices;
- Corrected file names of opened pages on the main program Title;
- Fixed paths for the result html-file on Export to HTML action (especially for Linux version);
- Graphs improved (summ() function now work into the control);
- Border supporting added to SMath Studio controls;
- Handheld: Fixed error when user "Save as" file without filling extension in File Name input - this file can rewrite existent one without any confirmation dialog;
- Desktop: Fixed errors with Save-On-Close dialogs;
- Text Control now can be removed by removing all it's text;
- Fixed "Esc = Backspace" issue;
- Desktop: 3D plot accuracy increased;
- Fixed critical error, when Plot graphs with large z-coordinate;
- Update dialog now can be setted up to check for stable updates only;
- Couple of errors in symbolic library fixed;
- Speed and stability improved;
- Code optimizations.
System requirements - Handheld:
Framework: .NET Compact Framework 2.0 cab (5,33МБ), zip (1,99МБ) Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, full VGA support, all PPC's, Comunicators and smartphones.
- Desktop (Windows):
Framework: .NET Framework 2.0
- Desktop (Linux):
Framework: Mono 2.0
Interface languages Desktop и Handheld (18 languages): [ENG] English / English [GER] German / Deutsch [DUT] Dutch / Nederlands [SPA] Spanish / Español [FRE] French / Français [POR] Portuguese / Português [CPP] Portuguese (Brazil) / Brazil (Português) [SCR] Croatian / Hrvatski [SCC] Serbian / Srpski [GRE] Greek / Ελληνικά [CZE] Czech / Čeština [HUN] Hungarian / Magyar [ITA] Italian / Italiano [POL] Polish / Polski [RUS] Russian / Русский [BUL] Bulgarian / Български [LTH] Lithuanian / Lietuvių [UKR] Ukrain / Українська
Free Download
* For installation of the program from PPC it is necessary to transfer a file on Your handheld computer (for example, with MS ActiveSync) and start it there with Your file manager. ** For installation of the program from PC it is necessary to install MS ActiveSync first.
