3 Pages123>
Offline MBernacca
#1 Posted : 05 December 2017 20:02:05(UTC)
MBernacca
Rank: Member
Just an exercise on Smath to test functionalities and capabilities.
Try the attached file and play with it.
Thanks
Marco
InterX.sm (86kb) downloaded 89 time(s).
thanks 1 user thanked MBernacca for this useful post.
on 19/02/2018(UTC)
#2 Posted : 06 December 2017 01:15:42(UTC)
Was thanked: 586 time(s) in 454 post(s)
Thanks Marco, works fine 6179,
Great piece of work !
Offline ndtma
#3 Posted : 06 December 2017 11:59:02(UTC)
ndtma
Sri Lanka
Was thanked: 55 time(s) in 36 post(s)
I get this error in SS 6528 (latest), and runs indefinitely?
The mind is everything. What you think you become.
Offline MBernacca
#4 Posted : 06 December 2017 12:21:31(UTC)
MBernacca
Rank: Member
Hello ndtma,
L1 is defined just near tt. You may try to move the tt definition a bit below in the page, to be sure that L1 definition comes first.
Regarding indefinite running, please be advised that due to the more complicate example that comes below in the sheet, the full worksheet takes 6,5 minutes on a pretty good hardware. Other hardwares may require more time, that could seem an indefinite time...
Try deleting the more complicate example, leaving only the simple one.
It should run in less than 1 minute.
Thanks
Marco
Offline PompelmoTell
#5 Posted : 06 December 2017 12:50:40(UTC)
PompelmoTell
Was thanked: 50 time(s) in 41 post(s)
Ndtma,
maybe that's why:
Some plugins are required and in particular:
- Matlab C++ Math Library
Attention: to my knowledge,this plugin only works with 32 bit version of Smath.
I am using 0.98 build 6484 dated 02 Oct 2017.
#6 Posted : 06 December 2017 13:37:54(UTC)
... ~ 21 min on my laptop [1.66 GHz]
#7 Posted : 06 December 2017 16:05:24(UTC)
Marco,
Just a detail: often we have to optimize project based on piecewise timing.
Smath accesses Microsoft internal timer, like this [attached].
Expect ~ 45 sec on your machine ... on mine => 1.6 min
Contour Butterfly.sm (15kb) downloaded 32 time(s).
Offline MBernacca
#8 Posted : 06 December 2017 16:31:03(UTC)
MBernacca
Rank: Member
Jean,
this is a fantastic feature I was not aware of!
I still have to look into the details but I think it is something like an animated GIF.
I'll go deeper in your worksheet later on to discover details.
Thanks for this hint!
Marco
Offline MBernacca
#9 Posted : 06 December 2017 18:46:09(UTC)
MBernacca
Rank: Member
Jean,
looking at your last post I have learnt a lot of things:
1) I didn't know that plots could be animated. This was a very nice example on this feature.
2) I didn't realize that placeholders can contain any kind of object. This means that definitions can be placed in a vector/matrix and treated as data. So instructions and data are on the same level (lisp docet!).
This opens the door to any kind of "black magic" like the simple example here attached.
3) Ahh..by the way I also understood about timing of code chunks...Biggrin
For all the above... thx!Clapping
Marco
BlackMagic.sm (8kb) downloaded 27 time(s).
#10 Posted : 06 December 2017 18:48:50(UTC)
Jean,
Marco
Few more typical animations. The Grand Champion Animate is Collab BER7.
He takes my dead cat and up dancing, isn't nice !
You can pass to any Windows user and animation survives [a Windows feature].
0Anim Brownian.sm (10kb) downloaded 19 time(s).
0Anim Cheval.sm (22kb) downloaded 17 time(s).
0Anim Gozilla.sm (12kb) downloaded 20 time(s).
Rotate Eol.sm (29kb) downloaded 17 time(s).
on 07/12/2017(UTC)
Offline Ber7
#11 Posted : 07 December 2017 20:50:54(UTC)
Ber7
Israel
Was thanked: 376 time(s) in 208 post(s)
If we add the third coordinate to the worksheet of Jean, we get a 3d animation.
3d Anim Brownian.sm (18kb) downloaded 18 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 07/12/2017(UTC)
#12 Posted : 07 December 2017 22:06:14(UTC)
Hello Marco,
On that one, for every calculated Ω, click on image, "Reset to original size"
Pattern Brownian Collect Image.sm (26kb) downloaded 17 time(s).
Offline MBernacca
#13 Posted : 08 December 2017 18:52:51(UTC)
MBernacca
Rank: Member
Still on line intersections.
Bug corrected: only lines with same number of points were accepted.
Now lines with different # of points will work.
Also some improvements in efficiency so that runtime is now
approx. -25%.
InterX.r1.sm (46kb) downloaded 19 time(s).
#14 Posted : 08 December 2017 21:45:19(UTC)
Some notes about "Vector partnership"
You mentioned Scilab [what a piece of software !!!], can't manage, removed from my box.
3D colors from whatever source is not available in Smath. Maxima as suggested by Martin,
complains ... useless. For your interest, Scilab should render the famous "Breather".
Attached as well.
Maths InterseX.r1.sm (66kb) downloaded 16 time(s).
Breather for UNI.sm (309kb) downloaded 14 time(s).
Rotate Breather [4 Orientations].sm (1,001kb) downloaded 17 time(s).
#15 Posted : 09 December 2017 01:37:56(UTC)
Was thanked: 745 time(s) in 480 post(s)
Did I miss the bug report?
Rotate1.sm (297kb) downloaded 21 time(s).
Pre-configured portable distribution of SMath Studio: https://en.smath.info/wi...th%20with%20Plugins.ashx
#16 Posted : 09 December 2017 15:02:25(UTC)
On starting Smath session, some dependencies aren't accessed.
#17 Posted : 09 December 2017 16:08:34(UTC)
Starting Smath, always get that error message, close, up running fine.
As it looks, only the Maxima X_Y. 3D surface and those from menu work.
NONE of "draw 2D, 3D, implicit, explicit as you suggest ..." work.
Thanks Martin for being there in Smath Community.
Offline MBernacca
#18 Posted : 09 December 2017 18:04:09(UTC)
MBernacca
Rank: Member
Jean,
I tried to render the Breather in Scilab.
The code is as small as this:
and it runs as fast as this, considering that U and V are given with 100 points each:
and this is the result:
from this side seems ok, but moving it a little bit it appears like this:
I am not sure if this is the expected result, but however I spent only 15 min on it up to now.
I'll check better if I messed something.
Thanks
Marco
Offline MBernacca
#19 Posted : 09 December 2017 18:27:18(UTC)
MBernacca
Rank: Member
Ok, using limits shown by Martin [(0, pi/2); (0, 2pi)]
I got something more similar to his result:
I'll work to see how to get the level curves.
Being Scilab an open source program, any chance that somebody could develop
a dedicated plugin?Biggrin
Maybe this is more a subject for the "Feature Request" Forum...Good
Marco
#20 Posted : 10 December 2017 01:06:20(UTC)
Are you using the current stable or development version of SMath?
Older versions won't work with the current plugin, as there were significant changes in the API.
If you follow the link in my signature you find instructions how to install a portable distribution with Maxima. The benefit of having a portable installation is that it won't interfere with an installed version of SMath and can be tested separately. So you don't need to spoil your familiar working environment.
If maxima still won't work, then please report the system information as obtained with Insert> Development tools> System Information.
Thanks for your help.
3 Pages123>
