Offline ioncube
#1 Posted : 19 December 2017 16:01:12(UTC)
ioncube
Pakistan
Was thanked: 2 time(s) in 2 post(s)
How will you go about solving following problem in Smath
Problem statement is as follows:
Quote:
On June 24, 1948, the former Soviet Union blocked all land and water routes through East Germany to Berlin. A gigantic airlift was organized using American and British planes to supply food, clothing and other supplies to more than 2 million people in West Berlin. The cargo capacity was 30,000 cubic feet for an American plane and 20,000 cubic feet for a British plane. To break the Soviet blockade, the Western Allies had to maximize cargo capacity, but were subject to the following restrictions: No more than 44 planes could be used. The larger American planes required 16 personnel per flight; double that of the requirement for the British planes. The total number of personnel available could not exceed 512. The cost of an American flight was $9000 and the cost of a British flight was $5000. The total weekly costs could note exceed $300,000. Find the number of American and British planes that were used to maximize cargo capacity.
Based on this the author & using an online LP solver I have:
http://prntscr.com/hpk4j5
#2 Posted : 19 December 2017 19:45:04(UTC)
Was thanked: 1120 time(s) in 718 post(s)
You can use the "simplex" package in Maxima (linear optimization)
See page Examples> Maxima usage> Linear optimization in the interactive handbook.
Example maxima linear optimization.sm (42kb) downloaded 23 time(s).
#3 Posted : 20 December 2017 03:12:22(UTC)
Was thanked: 980 time(s) in 808 post(s)
Maybe plot the problem 1rst ?
Next solve solely with Smath, whereas Maxima is not component of stable 6179.
Offline ioncube
#4 Posted : 20 December 2017 16:22:16(UTC)
ioncube
Pakistan
Thanks for the answers Jean would you be kind enough to attach the .sm file too. For field engineers like us your math skills seems rather cryptic & is digested properly after 2/3 days of experimenting Good
#5 Posted : 20 December 2017 17:59:15(UTC)
Here is + some extra stuff. Maybe there is way to draw an inscribed 3D ?
Solve GivenFind Critical Region Copy.sm (40kb) downloaded 27 time(s).
Offline CBG
#6 Posted : 21 December 2017 01:59:09(UTC)
CBG
Using Smath Studio with Maxima and the example of Martin Kraska.
Metodo_Simplex.sm (53kb) downloaded 23 time(s).
Offline CBG
#7 Posted : 21 December 2017 21:27:26(UTC)
CBG
Here is a small and simple Simplex algorithm without the use of the Maxima function.
Small_Simplex_Algorithm.sm (17kb) downloaded 22 time(s).
CAUTION: The algorithm is NOT TESTED, but it works well for this example.
It is necessary to refine it so that it work in all cases.
Edited by user 21 December 2017 22:13:26(UTC)  | Reason: Not specified
thanks 1 user thanked CBG for this useful post.
on 22/12/2017(UTC)
#8 Posted : 21 December 2017 22:10:07(UTC)
Thanks Carlos for the "Simplex algo"
Offline CBG
#9 Posted : 22 December 2017 07:40:32(UTC)
CBG
A little Simplex algorithm improved
Small_Simplex_Algorithm_Improved.sm (89kb) downloaded 20 time(s).
Offline CBG
#10 Posted : 22 December 2017 08:46:37(UTC)
CBG
I'm sorry, I found a bug in the Simplex algorithm.
Now it's fixed.
Small_Simplex_Algorithm_Improved_2.sm (136kb) downloaded 32 time(s).
#11 Posted : 22 December 2017 16:12:27(UTC)
That huge number in the program, can be replaced by ∞ [Smath machine number]
RemToDo => check vs Mathcad
First A[i ... badly indexed.
Small_Simplex_Algorithm_Improved_2.sm (141kb) downloaded 27 time(s).
on 22/12/2017(UTC)
Offline CBG
#12 Posted : 22 December 2017 18:57:52(UTC)
CBG
Thanks Jean, Now we just have to continue testing the Simplex algorithm, to identify possible faults.
regards
#13 Posted : 22 December 2017 19:38:07(UTC)
I have tested only this one => 1/1 Mathcad 11
Gorgeous, hope for more good !
Undocumented Copy.sm (26kb) downloaded 33 time(s).
