Offline ndtma
#1 Posted : 06 January 2018 16:04:31(UTC)
ndtma
Sri Lanka
Thank you Andrey for the latest SS: appVersion(4)="0.98.6580.5367" dated 06/01/2018.
Now I am unable to run all my SS files that use ZedGraph plug-in, and one such file is attached please.
Hydro Power Estimation-Wilson Ex 6.11.sm (208kb) downloaded 24 time(s).
Edited by user 06 January 2018 16:09:39(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#2 Posted : 06 January 2018 17:10:38(UTC)
Rank: Administration
Hello.
I've figured out what is an issue. It is because of the plug-in. We have two options here:
1) Fix the plug-in;
2) Open SMathStudio_Desktop.exe.config file with notepad (it is located into installation directory of SMath Studio) and edit it (you may need Admin rights) to make line with "v2.0.50727" before the line with "v4.0" as shown below:
Code:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v2.0.50727"/>
    <supportedRuntime version="v4.0"/>
  </startup>
</configuration>
Offline ndtma
#3 Posted : 06 January 2018 19:39:48(UTC)
ndtma
Sri Lanka
Thanks Andrey! With your Option 2, it works now with most of the problematic files, except the one which was attached.
I have to check it.
#4 Posted : 07 January 2018 06:40:09(UTC)
It works here 6179. There it seems it does not like units in cinterp
Your hatch seems damaged as well ... so sorry for the mess I did.
Hydro Power Estimation-Wilson Ex 6.11 fix.sm (230kb) downloaded 21 time(s).
Offline ndtma
#5 Posted : 07 January 2018 13:12:09(UTC)
ndtma
Sri Lanka
You are correct. My file was damaged, but I don't know why.
Thank you.
#6 Posted : 07 January 2018 17:53:52(UTC)
Thank you.
This happens, it did as well with Mathcad, was never explained.
Most curiously, it may happen after re-opening next day for a new session,
but from observation, it may happen several days. Does it have to do with
the Win update ? Ask Watson.
Once you have created the data set, indirectly it creates noise, because
it comes from collected data. For best result, integrate the data set
from finite differences, not from any interpolated reconstruction.
The finite differences integrator is the most powerful data smoother.
Trust me, I have tested from pure functions, made noisy.
As a result of the noisy data set, you can apply smoothing from ksmooth.
Doing so, you can reconstruct a derivative that makes sense.
That's what I did in the attached.
Hydro Power Estimation-Wilson Ex 6.11 Data.sm (42kb) downloaded 25 time(s).
