Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Thank you Andrey for the latest SS: appVersion(4)="0.98.6580.5367" dated 06/01/2018. Now I am unable to run all my SS files that use ZedGraph plug-in, and one such file is attached please. Hydro Power Estimation-Wilson Ex 6.11.sm (208kb) downloaded 24 time(s). Edited by user 06 January 2018 16:09:39(UTC)
Hello. I've figured out what is an issue. It is because of the plug-in. We have two options here: 1) Fix the plug-in; 2) Open SMathStudio_Desktop.exe.config file with notepad (it is located into installation directory of SMath Studio) and edit it (you may need Admin rights) to make line with "v2.0.50727" before the line with "v4.0" as shown below: Code:<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v2.0.50727"/>
<supportedRuntime version="v4.0"/>
</startup>
</configuration>
Thanks Andrey! With your Option 2, it works now with most of the problematic files, except the one which was attached. I have to check it. |
Originally Posted by: Jean Giraud It works here 6179. There it seems it does not like units in cinterp Your hatch seems damaged as well ... so sorry for the mess I did.
You are correct. My file was damaged, but I don't know why. Thank you. |
Originally Posted by: ndtma You are correct. My file was damaged, but I don't know why. Thank you. This happens, it did as well with Mathcad, was never explained. Most curiously, it may happen after re-opening next day for a new session, but from observation, it may happen several days. Does it have to do with the Win update ? Ask Watson. Once you have created the data set, indirectly it creates noise, because it comes from collected data. For best result, integrate the data set from finite differences, not from any interpolated reconstruction. The finite differences integrator is the most powerful data smoother. Trust me, I have tested from pure functions, made noisy. As a result of the noisy data set, you can apply smoothing from ksmooth. Doing so, you can reconstruct a derivative that makes sense. That's what I did in the attached. Jean Hydro Power Estimation-Wilson Ex 6.11 Data.sm (42kb) downloaded 25 time(s).
