SMath Studio Forum
Questions
That damned Trifolium makes me sick !
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Can't explain why yesterday I got a clean Trifolium, today it returns crappy again. It puzzled me for quite a while. I don't lie ... proof => clean InterseX posted last night. Made a backup last night, crappy today, Ah ! Why that 0 junction from stack(,,,) where there is none from construction ? It looks like the story of the last candy in the box and "Momy's cat". Worst than Murphy's law ! 2D Parametric Plot [Create Trifolium].sm (63kb) downloaded 27 time(s). ... Smath 6179
The files differ in the value of N, in the first file N = 100, and in the second file N = 30.
Originally Posted by: Ber7 The files differ in the value of N, in the first file N = 100, and in the second file N = 30. ... yesterday it doctored itself by coincidence during many attempts. This version is doctored [gray 235 ... can't explain . In short shadow in context ... occasional Mathcad/Mathematica. "shadow in context" is Mathematica expression of code can't be doctored. 2D Parametric Plot [Create Trifolium] Copy.sm (37kb) downloaded 18 time(s). ... doctored 6179
Jean, it seems to me that in the for operator there should be not N, but N + 1.
Originally Posted by: Ber7 Jean, it seems to me that in the for operator there should be not N, but N 1. Module xd(L,H,N) has fixed bounds [L, H], 'N' sets the number of calculated values, including the bounds. It has nothing to do with the "bug". The attached highlights the bug. Anything you code depend upon invisible/borrowed codes. This one may not appears in newer versions from newer sub-codes. Enable/disable => observe the Trifolium plot below. The Shadow in Context is between the triplet stack(f1,f2,f3) and the residual reverse[v,V4]. Conclusively: should be tested with more recent than SS 6179. It may suggest to get reverse & stack codes from other sources. It does not seems to be dependent upon the line code. 2D Parametric Plot [Create Trifolium] Copy.sm (38kb) downloaded 22 time(s).
SMath Studio Forum
Questions
