This document will extract the spline coefficients and will return these 4: 1. The splined plot/interpolation 2. The 1rst derivative plot/interpolate 3. The 2nd derivative as points, that you can linterp/interpolate 4. The cumulative integration, that you can linterp/interpolate In this demo document, we have used a function, but you can do same from your Engineering function or from your data set providing it is sufficiently clean/smooth. Enjoy, cheers ... Jean Spline l_p_c [ToolBox].sm (59kb) downloaded 47 time(s).
6.4 seconds on 0.99.6646 (i7 8850U).
