Offline Andrey Ivashov
#1 Posted : 13 March 2018 20:25:12(UTC)
Rank: Administration
Created by SMath LLC in the scope of SMath project. Published by smath.
SMath Studio box
The most important daily-use software for engineers. Far more powerful than actual Mathcad Prime. I actually use more SMath Studio than MS Excel at work. Thank you, Andrey, for this GEM. more...
by Alvaro Gavilán Rojas
I use this program on my everyday civil engineering calculations, and I highly recommend it! more...
by GiE
Excellent tool for electric engineering. Must have portable software on your USB key. Symbolic calculations is a great value for electronics. more...
by Igor Skarine
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
Edited by user 14 March 2018 23:00:03(UTC)  | Reason: Not specified
thanks 10 users thanked Andrey Ivashov for this useful post.
on 13/03/2018(UTC),  on 13/03/2018(UTC),  on 13/03/2018(UTC),  on 13/03/2018(UTC),  on 13/03/2018(UTC),  on 14/03/2018(UTC),  on 14/03/2018(UTC),  on 14/03/2018(UTC),  on 14/03/2018(UTC),  on 14/03/2018(UTC)
Offline alyles
#2 Posted : 13 March 2018 20:42:01(UTC)
alyles
United States
uMath Files Plugin appears to be broken with new release.
#3 Posted : 13 March 2018 20:58:12(UTC)
Thank you! Fixed and new plug-in version uploaded.
#4 Posted : 14 March 2018 18:53:10(UTC)
Updated version released: SMath Studio 0.99.6647.
#5 Posted : 14 March 2018 19:18:53(UTC)
The result formatting options of math regions aren't saved or handled correctly, see SS-3515.
Offline Jason McCool
#6 Posted : 14 March 2018 19:48:34(UTC)
Jason McCool
United States
Was thanked: 9 time(s) in 7 post(s)
Area controls seem to have been adversely affected with this build. A worksheet I have where a lot of the calcs are hidden inside separate areas to allow for the option of a "summary" calc or a "detailed" calc opened up almost completely unreadable. It appears the contents of the collapsed areas are being displayed over the top of each other all in 1 line instead of being hidden inside the area. See the attached screenshot. Also experiencing some instability when trying to click on the area "+" signs to expand them. The areas don't expand, and instead completely disappeared once. Deleting one area at the end of the worksheet deleted all the calcs (4 pages with all areas collapsed, 10 or so pages fully expanded) except for the part that had been inside the first collapsed area on the first page.
Thanks,
Jason
Jason McCool
Robbins Engineering
Little Rock, AR, USA
thanks 1 user thanked Jason McCool for this useful post.
on 14/03/2018(UTC)
#7 Posted : 14 March 2018 20:10:28(UTC)
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
Offline PompelmoTell
#8 Posted : 14 March 2018 22:24:20(UTC)
PompelmoTell
I experienced problems similar to those of Jason.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
#9 Posted : 14 March 2018 22:25:20(UTC)
Jason McCool
United States
Sorry, I forgot to check to get responses by email when I posted earlier. Here you go Good
C6 Channel Shear Tab.sm (229kb) downloaded 34 time(s).
Jason McCool
Robbins Engineering
#10 Posted : 14 March 2018 22:31:45(UTC)
Jason, I see this file was saved by SMath Studio 0.99.6646.16669 and already have problems.
Do you have the initial version?
#11 Posted : 14 March 2018 22:33:56(UTC)
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
#12 Posted : 14 March 2018 22:46:23(UTC)
Jason McCool
United States
I actually hadn't meant to be using beta versions on my production work, but I apparently unchecked the "exclude beta versions" at some point recently and had saved that worksheet in build 6646. It seemed to work well yesterday, and I have a pdf printout that doesn't show any issues with the display of the collapsed areas, but that was printed to pdf prior to saving and closing, so perhaps it is the same behavior as for Sergio. I had to finish getting some calcs ready for a client today, so I reinstalled the last stable build from the website this afternoon, and can't confirm the behavior now with any of the beta builds. But here is the original worksheet that works in build 6622. Thanks!
Jason
Channel Shear Tab.sm (229kb) downloaded 33 time(s).
Jason McCool
Robbins Engineering
#13 Posted : 14 March 2018 22:46:36(UTC)
Thank you Jason and Sergio!
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Thank you very much for the report and your help!
Edited by user 14 March 2018 22:49:08(UTC)  | Reason: Not specified
on 14/03/2018(UTC)
#14 Posted : 14 March 2018 22:52:50(UTC)
PompelmoTell
prova1.sm (3kb) downloaded 32 time(s).
it's a trivial file. When I saved it, it appeared correctly but if I open it, the error occurs on the collapsed area
