Was thanked: 4 time(s) in 2 post(s)
Hi, my problem is that if I select whole text line and try to copy it and paste to notepad (or back to the same SMath sheet) I get only part of selected text. Steps to reproduce: 1. open new worksheet 2. input this text: Quote:a el(Re.a,1,1):{nthroot(Re/b,3)+sqrt(3.6)}/sin(3)/{4^{2-o}}} - as there is a space as second char, this is treated as text region (alternatively one can use Insert->Text region and then insert this text or similar). Then double click on inserted text. All text is selected. Then copy (^C) and paste it (^V). Only part of text is copied. Attached sample file. selection_copy_bug.sm (3kb) downloaded 17 time(s).
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: m227 my problem is that if I select whole text line and try to copy it and paste to notepad (or back to the same SMath sheet) I get only part of selected text. Just paste and manage the disposition.
