This is a subset of a larger sheet. Delta T should be 0, 15, 15 and I get 0, 23, 15. I zeroed out the first heat input and got a large imbedded matrix for unknown reason, that is secondary SMath.smz (6kb) downloaded 12 time(s).
Originally Posted by: ElSid ... and got a large imbedded matrix for unknown reason ... It carries 'i' from previous use and it has to be cleared in some way. That is one of many cases of shadow in context, very annoying has it does not clear the previous matrix. ElsidDoctored.sm (11kb) downloaded 9 time(s).
Appears to carry everything though and just evaluates the last value Forgot to post. I changed q.w to check values on the top SMath.smz (6kb) downloaded 8 time(s).It's in the loop. If I write an equation dt[1:f.dtv(1) above the program, I get one value array. As I scroll it down, it becomes a 3 value array Jean, it should not clear the matrix, but build it. Maybe look into stacking it Edited by user 13 July 2018 06:15:47(UTC)
| Reason: Verbiage
Looks like it was a structure in the program. I had a "double" program line to start the loop. Cleaned it up and appears to work correctly. Input is always welcome SMath.smz (6kb) downloaded 17 time(s).
Originally Posted by: ElSid Maybe look into stacking it SHOULD BE 15, 15 and .0017. What's wrong? Just collect as you figure it should be. SMath [2].smz (6kb) downloaded 13 time(s).
