Was thanked: 16 time(s) in 7 post(s)
Is it possible to add the file path in addition to the filename in the window title bar?
Or maybe make it a preferences checkbox option. Often times when using a repetitive calculation, I find that I am working on the one in the wrong folder.
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: sinneD Often times when using a repetitive calculation, I find that I am working on the one in the wrong folder. Hard to understand why working the same document in different folders. To minimize crashing save the same document in the same folder Save as copy ... alternate between the copy and the not copy .
Originally Posted by: sinneD Is it possible to add the file path in addition to the filename in the window title bar?
Hi. You can see the Document Directory with the Mathcad Plugin, not in the toolbar but in the SMath document: Best regards. Alvaro.
