Joined: 20/08/2018(UTC) Posts: 4 Location: Manchester
Hi, I am new in sMath topic. Can anybody tell me why here my combobox doesn't work correctly? It doesn't download values from rows. Thanks! Lifters check.sm (21kb) downloaded 43 time(s).Edited by user 20 August 2018 12:56:49(UTC)
I have identified two errors: 1) you must assign a variable to the combobox 2) seems to have disabled the evaluation of the combobox sergio
1 user thanked PompelmoTell for this useful post.
Sergio, Your snippets and Uni snippets can't be viewed. How do you mange to make them so microscopic ! Mines are always 1/1 from captured very fast. Jean
Jean, did you click on the image? it should automatically expand to normal size. Later you can further enlarge it with Ctrl + (+)
Originally Posted by: PompelmoTell Jean, did you click on the image? it should automatically expand to normal size. Later you can further enlarge it with Ctrl ( )
sergio Clicking on the image in the forum it expands a bit. To view it original you have to Ctrl+ several times. Returning to the forum, then Ctrl- as many times. The capture method is the normal way. The capture from WinGrab [freeware] can be pasted directly in Paint Win 7. I was replied by [kept anonymous] a major Smath authority "If I don't see something, don't open" May be not exact wording. Thanks Sergio.
1. click WinGrab [task bar] 2. click "Capture" [winGrab menu] 3. F11 [or as user options] ... screen is in WinGrab 4. "Selection tool" [WinGrab menu] ... adjust selection 5. selection is done ... "Crop image" [WinGrab menu] 6. "Save as" *.PNG ... Windows remember were to save in my box it saves in C:\Snippets. 7. Upload in Forum , bingo from the Snippet Directory. The last saved snippet is always at top ... double click/done in queue of the Forum. No Ctrl+++ ... No Ctrl---- back to forum On the image in the Forum "Copy image", Paste in Smath Why reduce baby elephant to the mouse size ?
Originally Posted by: Jean Giraud Why reduce baby elephant to the mouse size ? Big images might be an issue on metered connections and more in general they makes harder to navigate a thread (the spoiler bbcode is useful too in these cases); this kind of "widget" is available on almost any forum board, the image is available on full size, but is hidden behind a thumbnail. However the thumbnail above it expands depending on the device, thus why it might appears tiny even when clicked depending on your screen size... in most browsers a right click on the "expanded to screen" popup allows to open the image in another tab at full size, and a download link is available on the bottom of the same popup. Edited by user 21 August 2018 02:44:58(UTC)
The original image would scare a crow ! 1. WinGrab capture from web 2. paste in IrfanView, Resize/Resample 87.5% 3. while in IrfanView: Sharpen twice 4. Resize/resample again 87.5% 5. Sharpen twice again ... clean, convenient size for Smath document
Originally Posted by: PompelmoTell I have identified two errors: 1) you must assign a variable to the combobox 2) seems to have disabled the evaluation of the combobox sergio Sergio, can you send me a correct file if it's not a problem? I now what you mean but that will be the easiest way for me. I still have something incorrect. Thanks for help
... alternately from work sheet Combobx captured via WinGrab adds frame around.
Thanks Sergio! Unfortunately I have another problem. Combobox command "Requested element doesn't exist" and I can't find the answer. If you can, please check the file for me. Thanks in advance! Restraint_bracket.sm (16kb) downloaded 17 time(s).
Thanks Sergio, it is definitely easier way. Do you now way it's not working similar to lifters file? And why in both files I can't add another row/column to matrix by creating value in nonexistent row/column and then recreating matrix? This manner it's not working. Maybe any other way to easy add row/column.
Sorry to bother You. Cheers
