Hello, I have an issue when I try to inverse matrix without defining new variable Smath does a calculation, but when I try to define new variable with value of inversed matrix smath stucks in calculation. I attached a file, hope You can help me RAMA3.sm (53kb) downloaded 23 time(s).
Try the eval () function
By opening your file, errors correspond to two incomplete formulas. If you delete the two missing terms (one for formula) and if you set the rating to "numeric" (in your file The two formulas are set to "symbolic" , everything will work correctly. Sergio
Originally Posted by: Lazarion but when I try to define new variable with value of inversed matrix smath stucks in calculation. Few things are not defined. Doctored in red, red is numeric. Observe ... diag(v) RAMA3.sm (69kb) downloaded 21 time(s).
Formulas was incomplete because of having problems with calculating equation. Your solutions helped me. Thank You everyone, thread's exhausted
