Dentro del ámbito de la investigación y desarrollo electrónico es una herramienta completa para realizar los análisis preliminares y más. / Within the field of electronic research and development, it is a complete tool for preliminary analysis and more.
more...
by Cristian Matorra
Pozdrawiam wszystkich użytkowników i zachęcam do wspierania produktu.
more...
by LeszekP
I needed the simplest functions, which I did in Mathcad. Now this software does everything I need. Keep up the good work. Brilliant. Thank you.
more...
by Kunt Celebi
on 30/10/2018(UTC), on 30/10/2018(UTC), on 30/10/2018(UTC), on 31/10/2018(UTC), on 01/11/2018(UTC)
Sometimes I test new versions of Smath with my very old worksheet which keeps failing since 0.98.5973. This time it puzzled me again. Please see how it performs now. The SS prints the result of maple(expand(...)) normally, but after assigning the resulting expression to the variable nnn, it failed even to display nnn. What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s).Edited by user 01 November 2018 03:29:59(UTC)
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: tomtit Sometimes I test new versions of Smath with my very old worksheet Maybe just like this Tom ... like 5346, 6179
Originally Posted by: tomtit ... What means "Not defined" if it has shown the correct result before? example_5973.sm (11kb) downloaded 39 time(s). Hi. It means that can't recalculate because the use of sums and products. For force the recalculation as it is needed, can enclose the num definition by a line: Best regards. Alvaro.
