  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,641   Was thanked: 1400 time(s) in 817 post(s)
 Plugin updated. This string representation is standard for c# Font type. Changes: - added font setting for text labels. xyplot-text-lablels-font-example.sm (7kb) downloaded 19 time(s). Edited by user 07 December 2024 01:13:08(UTC)
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
 5 users thanked uni for this useful post.
on 07/12/2024(UTC), on 07/12/2024(UTC), on 07/12/2024(UTC), on 07/12/2024(UTC), on 07/12/2024(UTC)
Joined: 23/12/2012(UTC) Posts: 96  Was thanked: 171 time(s) in 134 post(s)
Thanks Viacheslav for this excellent work Would it be possible to add the font color ? |
Do to others as you would like them to do to you! Knowledge is of no value unless you put it into practice - Chekhov |
The color can be set in the same way as before.  |
 4 users thanked uni for this useful post.
Joined: 16/04/2023(UTC) Posts: 38  Location: Rome Was thanked: 12 time(s) in 9 post(s)
Now Uni there is a last effort ro address the issue of the font zooming , I imagine that it would be possible to trap the mouse weel event and scale the fonts used in the text in the XY Plot Plugin accordingly. My best wishes to succeed , best regards
Franco
Joined: 28/08/2014(UTC) Posts: 1,533  Was thanked: 990 time(s) in 618 post(s)
 3 users thanked Razonar for this useful post.
on 15/12/2024(UTC), on 16/12/2024(UTC), on 16/12/2024(UTC)
Joined: 04/12/2017(UTC) Posts: 72   Was thanked: 3 time(s) in 3 post(s)
In this post @mkraska referred: Quote:In X-Y Plot, you can use geometric objects to create the lines and perhaps also a legend. What does he mean?
Originally Posted by: ioncube  What does he mean? Something like that I suppose.  |
Joined: 15/04/2012(UTC) Posts: 2,048  Was thanked: 1177 time(s) in 752 post(s)
 3 users thanked mkraska for this useful post.
on 18/12/2024(UTC), on 18/12/2024(UTC), on 18/12/2024(UTC)
Hi. How to fill a half plane and a half wave?  filling question.sm (6kb) downloaded 8 time(s).Best regards. Alvaro.
Joined: 10/12/2009(UTC) Posts: 289   Location: Cali, Colombia Was thanked: 124 time(s) in 83 post(s)
 3 users thanked oscampo for this useful post.
Originally Posted by: oscampo  Some manipulations... Gracias Oscar! Very clever solutions, especially the half plane one. Best regards. Alvaro.
Originally Posted by: mkraska  Somehow I don't manage to produce the traces settings in a loop. This needs to be done differently. Alvaro showed a working version somewhere here. You need to include the assignment sign in the string and then transform the text expression in a cycle. The thing is that substitution in curly brackets is not a native operation, but a feature of the component. Therefore, the substitution will not occur this way; you need to form the full expression in the text representation. spherical aberration.sm (27kb) downloaded 11 time(s). Edited by user 18 December 2024 23:03:36(UTC)
An example...  Assign Properties by Loop.sm (20kb) downloaded 6 time(s).Best, Oscar Edited by user 19 December 2024 00:42:40(UTC)
Originally Posted by: Razonar  Hi. How to fill a half plane and a half wave? I might try adding behavior for endpoints when filling paths. Right now the default behavior is to just close the endpoints, but that behavior could be changed. For that, I'd need to iterate over all possible use cases. |
Originally Posted by: uni  Originally Posted by: Razonar  Hi. How to fill a half plane and a half wave? I might try adding behavior for endpoints when filling paths. Right now the default behavior is to just close the endpoints, but that behavior could be changed. For that, I'd need to iterate over all possible use cases. In Maxima draw, there is an option filled_function, which allows to specify a second function which defines the other side of the fill. Simply saying 0 fills to the axis, some big value fills to the boundary (top or bottom). This is much like in the hatch snippet, where 2 functions are specified. In X-Y plot you could take a second function of the same variable in a row or in a list (just like with parametric functions, just with undefined dummy variable or you could say "to next", referring to the next trace, other options could be "to x", "to y", "to top" "close along border" etc. |
on 19/12/2024(UTC), on 19/12/2024(UTC)
So I understand if I don't use {} in a loop then I am safe. Of course, I could use p while building the string in the loop. ![2024-12-18 14_28_13-SMath Solver - [NaOH_Demiwater_VECTOR_Kr.sm].png](/forum/resource.ashx?a=50321&b=2) NaOH_Demiwater_VECTOR_Kr.sm (198kb) downloaded 5 time(s). |
Originally Posted by: mkraska  ... In Maxima draw, there is an option filled_function, which allows to specify a second function which defines the other side of the fill. Simply saying 0 fills to the axis, some big value fills to the boundary (top or bottom). This is much like in the hatch snippet, where 2 functions are specified. Thanks Martin! It works fine.  draw2d-filled.sm (30kb) downloaded 9 time(s).Originally Posted by: mkraska  ... In X-Y plot you could take a second function of the same variable in a row or in a list (just like with parametric functions, just with undefined dummy variable or you could say "to next", referring to the next trace, other options could be "to x", "to y", "to top" "close along border" etc. I don't know how to do that. Best regards. Alvaro.
Originally Posted by: Razonar  Originally Posted by: mkraska  ... In X-Y plot you could take a second function of the same variable in a row or in a list (just like with parametric functions, just with undefined dummy variable or you could say "to next", referring to the next trace, other options could be "to x", "to y", "to top" "close along border" etc. I don't know how to do that. Best regards. Alvaro. That was just a proposal as to what control options I'd find useful. |
Originally Posted by: mkraska  ... That was just a proposal as to what control options I'd find useful. Thanks Martin. I found it very useful too, and I thought it was already a reality. Although I think my reading comprehension was not at its best level. Best regards. Alvaro. Edited by user 19 December 2024 17:35:00(UTC)
A way for filling the region between curves, combining Oscar's box and Martin's fill_func.  XYFilling.sm (25kb) downloaded 18 time(s).Best regards. Alvaro. Edited by user 20 December 2024 14:46:40(UTC)
| Reason: Added half planes
 5 users thanked Razonar for this useful post.
on 20/12/2024(UTC), on 20/12/2024(UTC), on 20/12/2024(UTC), on 21/12/2024(UTC), on 21/12/2024(UTC)
