8 Pages«<23456>»
Offline brotjob
#61 Posted : 16 December 2014 21:54:45(UTC)
brotjob
Switzerland
Was thanked: 7 time(s) in 7 post(s)
I can confirm this bug. I am sure Viacheslav will find a fix for this.
But what I still don't understand: Shall we see the include plugin as the definitive solution or shall we push to get a smath integrated core include function? I ask this because Vicheslav himself wrote that only Andrey can program a "real" include.
Offline Owndante
#62 Posted : 17 December 2014 10:45:35(UTC)
Owndante
Rank: Member
There are a few extensions that I would gladly see it in the core software, and "include" in one of them.
Offline uni
#63 Posted : 17 December 2014 11:52:51(UTC)
uni
I spoke with Andrey on this. He is not yet able to implement it as an internal function. He said that the full realization of such function is difficult now. But in the future it is planned.
As for the bug. Functions (regions) from the external plug-ins (for the include file) are not supported yet. I'll try to add such possibility, but not sure what I can. I did not expect such use. You ask for features that should support mathematical package, but not a simple function.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Owndante
#64 Posted : 17 December 2014 13:41:41(UTC)
Owndante
Rank: Member
Thanks!
Offline RFreund
#65 Posted : 18 December 2014 21:21:02(UTC)
RFreund
United States
Is it correct that the variables/values in the referenced file cannot be inside of an 'area'?
Offline uni
#66 Posted : 18 December 2014 21:44:41(UTC)
uni
As I wrote above, we have found a bug in the program when saving a file with the areas. The error is related to the wrong location closing tag for the area. This leads to the fact that the function incorrectly interprets the data in the other areas or to ignore them. Andrey will fix this. After that you can use the variables within areas.
Russia ☭ forever
Offline uni
#67 Posted : 08 April 2015 11:31:50(UTC)
uni
Examples.
File Attachment(s):
a.sm (5kb) downloaded 56 time(s).
b.sm (6kb) downloaded 49 time(s).
c.sm (9kb) downloaded 48 time(s).
Russia ☭ forever
Offline bAiLeY
#68 Posted : 16 June 2015 21:50:31(UTC)
bAiLeY
Is there any update on the Areas bug?
Offline uni
#69 Posted : 05 August 2015 20:57:19(UTC)
uni
Bug was fixed in the SMath Studio 0.97.5581, but something wrong happening again with the nested function call.
Russia ☭ forever
Offline uni
#70 Posted : 07 August 2015 19:37:14(UTC)
uni
Updated.
Russia ☭ forever
Offline RFreund
#71 Posted : 27 August 2015 17:17:42(UTC)
RFreund
United States
I was just curious - has there been any updates regarding the use of areas and include.
As I understand it. If there is work inside of an area it will not be transferred to the file which uses the 'include' statement, correct?
I could see this being good and bad. It's nice to have a way to keep variables from following to the include file but at the same time I use areas to help organize my sheets, hmm....
Offline uni
#72 Posted : 07 September 2015 08:01:19(UTC)
uni
Hmm... I see now that include function supports only one level depth for areas, variables in nested areas are invisible. I'll try to fix this.
Russia ☭ forever
Offline RFreund
#73 Posted : 04 October 2015 04:52:26(UTC)
RFreund
United States
It's actually not so bad to have Nested areas not transfer as it provides a way to keep some variables from not transferring.
However, a problem occurs when I have a function that is nested in an area. For example:
In sheet 1 the values for q.WL are found from a function which is in a collapsed area.
In sheet 2 we include "sheet 1.sm". We ask for the values of q.WL however they cannot be retrieved because it claims that the function is not defined.
I'd like the include to include the values in q.WL without requiring the function to be brought into sheet 2. At least I think that's what I would want...
Offline RFreund
#74 Posted : 20 October 2015 21:39:12(UTC)
RFreund
United States
What about including only certain variables?
Offline RFreund
#75 Posted : 20 October 2015 23:41:30(UTC)
RFreund
United States
Another issue seems to be including variables which were defined in a "For Loop". Not sure why that is. Any thoughts?
Offline uni
#76 Posted : 21 October 2015 14:40:37(UTC)
uni
Because it creates a set of variable definitions I think. This is normal.
Russia ☭ forever
Offline RFreund
#77 Posted : 21 October 2015 15:38:02(UTC)
RFreund
United States
So is there anyway to include variables created in for loops?
Offline uni
#78 Posted : 21 October 2015 15:56:20(UTC)
uni
Show me an example. What do you have and what you want to avoid.
Russia ☭ forever
Offline RFreund
#79 Posted : 24 October 2015 20:12:53(UTC)
RFreund
United States
Uni ->
Attached is the file that I had problems with. There is a lot of information there that I was trying to whittle down but I kept messing up the actual issue. I did however find where the problem occurs:
I define a matrix by placing a summation into the matrix. Then this variable is used in a "for" loop. I'm not sure where the error occurs.
There are three .sm files - I only included "loads" so that the they would all work properly but I don't think there is anything useful in there. I've highlighted the issue in red which occurs in the "Loads - EQ Low_Test.sm" file. The problem is seen on the Test.sm file.
Let me know if it is too confusing; I can continue to try and reduce the files.
Thanks!
File Attachment(s):
Include.7z (801kb) downloaded 44 time(s).
thanks 1 user thanked RFreund for this useful post.
on 24/10/2015(UTC)
#80 Posted : 25 October 2015 06:53:43(UTC)
There are a few extensions that I would gladly see it in the core software, and "include" in one of them. [Owndante]
________________________
The Smath version I downloaded April 2015 comes with "include(,)", Smath menu, f(x), here is.
It looks doing something like "Reference" in Mathcad. In ~ 125000 exchanges Mathsoft Collaboratory
I bet < 12 work sheets were exchanged with reference to other work sheet. It might be useful in Smath
from prime consideration but in fact it is limited to specific functions, some type of program that
would be cumbersome otherwise ... but the collapsed area is a much better approach as it keeps the
document stand alone. The Smath collapsed area has its own problem. In my Smath version, it doesn't
push down the regions below the collapsed area ... result: when collapsing again all the regions
are messed and very hard to recuperate. Surprising because *.Sm from Draghilev method they push down
the regions.
All that said, a good example for "include(,) is the Bessel JZERO, JONE, YZERO, YONE
They are monster formulas that one is better let them sleep hiden. Another good use would be to
collect Physical/Chemical/.... constants as well as the several pages of Mathcad constants.
If somebody wants them, just ask for ,,, *.bmp, bingo and patience to reinstall in Smath.
Thanks, very interesting.
Cheers, Jean.
Similar Topics
Display formula stored in "Included" SMath file (Questions)
by faruk 10/03/2024 23:36:28(UTC)
include files @ startup (Questions)
by charlamb 10/05/2023 23:44:05(UTC)
Adidas include guaranteed with the 12 months (Bugs & Problems)
by Guest 11/12/2020 07:02:55(UTC)
include function issues (Questions)
by jrufener 01/06/2019 21:44:47(UTC)
[include plugin] missing LinqBridge.dll error in SMath Viewer executables (Bugs & Problems)
by resist 24/11/2017 18:07:37(UTC)
Include [User Program Function] (Feature Requests)
by Jean Giraud 16/04/2016 15:29:14(UTC)
"include" plugin: default directory setting (Feature Requests)
by mikekaganski 04/04/2016 07:19:58(UTC)
Include and Combobox Region (Questions)
by RFreund 01/03/2016 02:18:21(UTC)
include does not seem to work anymore (Bugs & Problems)
by Tinu 23/06/2014 09:56:03(UTC)
Even so Kobe Shoes includes by no means offered " up " their particular method to Nike Air condition (Questions)
by gladys 07/06/2014 05:27:07(UTC)
Include Hook Sections (Feature Requests)
by sublim21 29/05/2013 21:23:33(UTC)
Include ksi and ksf in next release (Feature Requests)
by TheWizEd 17/07/2010 22:42:11(UTC)
Include function (Feature Requests)
by LordMike 24/10/2009 05:15:45(UTC)
8 Pages«<23456>»
