Offline Oichi
#1 Posted : 09 February 2023 01:55:53(UTC)
Oichi
Woman
Viet Nam
Was thanked: 3 time(s) in 3 post(s)
I downloaded SMath Studio AppImage from the website on ubuntu 22.04. Whenever I open it, it loads that green loading box attached below then it crashes. Any help please?. Thanks in advance
Edited by user 09 February 2023 01:59:33(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 09 February 2023 14:28:22(UTC)
Turkey
Was thanked: 534 time(s) in 358 post(s)
Try to run with sudo.
Whether appimage or regular, it won't run without sudo.
Well it will, but you must try a lot of times to make it run.
A link to a thread for further examination
This is a mono bug specific to debian distros except for one.
It is related with glibc and kernel version I suppose.
As far as I know due to my experience, only Debian based
distro I could run SMath without sudo is MXLinux (ahs).
If SMath doesn't run even, please run it under a terminal.
And post terminal output here, maybe it is a faulty plugin.
Offline mocarny_knur
#3 Posted : 13 December 2023 00:51:26(UTC)
mocarny_knur
Poland
I created account on this forum only to write that if You install in Ubuntu 22.04:
libmono-cil-dev
libmono-db2-1.0-cil
mono-dbg
mono-devel
mono-tools-devel
then it should work without sudo. This is some bug within mono and installing mono debugging allows it to run apparently.
Offline ioncube
#4 Posted : 15 September 2024 08:33:00(UTC)
ioncube
Pakistan
I am running SMath on my OrangePi-3b arm64 so far so good. Can anyone tell me how to use GTK themes for mono applications. SMath looks ugly
Offline overlord
#5 Posted : 16 September 2024 06:49:21(UTC)
Turkey
Especially if your theme is dark for linux, SMath becomes unusable.
Buttons can't be seen, toolbars are too dark, etc.
So I edit smathstudio_desktop_mono file as below.
Code:
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}")")"
cd "${HERE}"
export MONO_WINFORMS_XIM_STYLE=disabled; GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//Solver.exe" "$@"
I use smath with a light default theme from /usr/share/themes/.
WINFORMS option also fixes ubuntu/debian crash.
Offline ioncube
#6 Posted : 16 September 2024 15:41:19(UTC)
ioncube
Pakistan
Thanks Overlord, the thing is that developers should move from MONO to dotnet6/7/8 these are available in all Linux distributions! Recently a popular photo editor Pinta moved from MONO to dotnet8 ...similarly calcpad also did that & is very usable in Linux
thanks 1 user thanked ioncube for this useful post.
on 16/09/2024(UTC)
Offline overlord
#7 Posted : 16 September 2024 22:12:13(UTC)
Turkey
Actually, not every distribution has dotnet in their repository.
Some major ones like fedora or ubuntu have it, but rest doesn't.
Offline ioncube
#8 Posted : 17 September 2024 13:33:38(UTC)
ioncube
Pakistan
overlord, I did that (customised run script) but Rayleigh theme was not loaded. I tested location / files ...content is there but theme is not loaded. Any suggestions?
Offline overlord
#9 Posted : 18 September 2024 00:15:18(UTC)
Turkey
If smath window is light themed, it should have ben loaded.
As far as I know, mono2 applications doesn't accept themes designs except colors.
Similar Topics
[SS-2344] Paste Error in Smath Studio on Linux Mint (Bugs & Problems)
by vkt 13/05/2016 20:10:58(UTC)
