Offline soomoon
#1 Posted : 30 August 2024 14:11:47(UTC)
soomoon
Korea, Republic Of
he first formula calculated well.
The second formula did not calculate.
The result is "The stack is empty."
What is the problem?
2024-08-30 10 10 50.png stack_is_empty.sm (9kb) downloaded 2 time(s).
Offline overlord
#2 Posted : 30 August 2024 15:18:59(UTC)
Turkey
Was thanked: 534 time(s) in 358 post(s)
Either clear R or use a different variable name, R.1 for example.
Because you defined R at upper calculation, it confuses solvers.
