Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 425 Was thanked: 42 time(s) in 39 post(s)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,710 Location: Italy Was thanked: 1378 time(s) in 902 post(s)
You can guess by the error message (function is not defined). The key is that you are using a recursive pattern, and in the first case the internal Factorial() can't be calculated because the context in which the function runs is the "top level" (the canvas), where Factorial(1) doesn't yet exists (it will exists for the next region on the closest canvas pixel on the right side). The line() on the RHS of a define operator (colon) creates a sub-level that inherit everything from the higher level(s) including the function whom the line() belongs, and that's why the second function works as you expect. The bottom examples are unrelated because are not recursive. Hope it helps. Edited by user 13 September 2024 20:17:15(UTC)
