Hi, Newbie here I am using Smath Studio with Maxima. MaximaTakeover("all" :"diff(), int(), sum(), det() handled by Maxima" But does not work when i insert int(x,x). Why? Worksheet1.sm (3kb) downloaded 0 time(s).I am using this version of Smath: I am using this version of Maxima: Check Maxima if works in Smath: Edited by user 04 October 2024 21:27:31(UTC)
Ok, I saw where the mistake comes from. I put definition sign := aflter MaximaTakeover():=, and should be evaluate numerically sign MaximaTakeover()= Problem solved. Edited by moderator 05 October 2024 01:04:00(UTC)
