Joined: 23/07/2013(UTC) Posts: 1,198  Was thanked: 548 time(s) in 368 post(s)
With X-Y Plot plugin new fill feature, it is easier to make nice plots. Let's make this a challenge, upload your country flag under this post. Here is my country's flag totally accurate to our flag standard. Regards flag_tr.sm (10kb) downloaded 14 time(s).
 3 users thanked overlord for this useful post.
on 18/11/2024(UTC), on 18/11/2024(UTC), on 19/11/2024(UTC)
Joined: 10/12/2009(UTC) Posts: 289   Location: Cali, Colombia Was thanked: 124 time(s) in 83 post(s)
Hi
! Here is my contribution. The flag design of my country is very simple, so I add some waves to make it more interesting. flag_CO.sm (15kb) downloaded 6 time(s). Regards!!
 1 user thanked oscampo for this useful post.
Joined: 30/09/2012(UTC) Posts: 64  Was thanked: 13 time(s) in 8 post(s)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,641   Was thanked: 1400 time(s) in 817 post(s)
I like to approach things universally, so I found svg pictures of all the flags. All that's left is to implement their rendering. Then everyone will be happy. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
Joined: 10/01/2017(UTC) Posts: 34   Location: Alberta
Hi, for some reason the flag is not filled as it is shown? this is how it shows on my version now (V1.2 built 9018 dated 09-sep-2024) this is the flag with no fill:  Edited by user 19 November 2024 07:25:07(UTC)
Originally Posted by: Mido0  Hi, for some reason the flag is not filled as it is shown? also, I noticed that the "properties source" in the formatting options is gone now, so how can we adjust the max/min and ticks by code? Thanks this is how it shows on my version now (V1.2 built 9018 dated 09-sep-2024)
this is the old version where the "properties source" is shown
... You must to update the X-Y Plot Plugin
Thanks, I just realised the plugin has changed.. I am reading through to see how to fix the old code.
Joined: 28/08/2014(UTC) Posts: 1,533  Was thanked: 989 time(s) in 618 post(s)
Hi Overlord. My contribution too. If the flag is not too complicated you can try programming its path using SVG commands in SMath with this file (taken from here, but due to the bug with <, > and & it no longer works well). Or simply use the text with the SVG commands and display it in an image component:  svg_uy_flag.sm (300kb) downloaded 10 time(s).Best regards. Alvaro.
Originally Posted by: Razonar  Hi Overlord. My contribution too. If the flag is not too complicated you can try programming its path using SVG commands in SMath with this file (taken from here, but due to the bug with <, > and & it no longer works well). Or simply use the text with the SVG commands and display it in an image component: ... Best regards. Alvaro. Hi Alvaro, I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (288kb) downloaded 15 time(s).Best wishes, Oscar
 2 users thanked oscampo for this useful post.
on 20/11/2024(UTC), on 20/11/2024(UTC)
Originally Posted by: oscampo  Hi Alvaro, I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (288kb) downloaded 15 time(s). Hola Oscar. Gracias! Un abrazo. Alvaro.
Joined: 11/01/2018(UTC) Posts: 153   Location: Wisconsin Was thanked: 73 time(s) in 46 post(s)
Greetings, Here is my candidate: May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
 1 user thanked Kenny Lemens for this useful post.
