Offline uni
#1 Posted : 22 November 2024 13:14:57(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
SpiceSharp (Spice#) - electronic circuit simulator
SMath Studio compatibility Sources
Based on SpiceSharpParser (.NET library that allows to parse SPICE netlists and to simulate them using SpiceSharp library).
This plugin requires .Net Framework 4.7.2 to be installed for it to work.
I managed to run the first test example on my PC. The plugin is not available on the server yet.
Links:
1. SpiceSharpParser
2. SpiceSharp Home Page
Edited by user 23 November 2024 01:27:35(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 23/11/2024(UTC)
Offline uni
#2 Posted : 22 November 2024 13:30:22(UTC)
uni
For experts only.
spice#.sm (6kb) downloaded 9 time(s).
Plugins folder: C:\Users\User\AppData\Roaming\SMath\extensions\plugins
SpiceSharp-0.1.9092.9246.zip (11,211kb) downloaded 7 time(s).
on 22/11/2024(UTC),  on 23/11/2024(UTC)
Offline Razonar
#3 Posted : 25 November 2024 18:45:27(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Hi. A preview for exploring this powerful plugin.
spice# and MNA.sm (578kb) downloaded 10 time(s).
spice# and MNA.pdf (1,546kb) downloaded 20 time(s).
on 25/11/2024(UTC)
Offline uni
#4 Posted : 25 November 2024 19:05:39(UTC)
uni
I haven't even tried these features myself yet. Support for all types of analysis hasn't been tested. There's still a lot of work to do. Maybe I'll do a direct insertion of values ​​into the circuit description. I wanted to try making a circuit with an amplitude detector. The authors have recently added the ability to specify an amplitude-modulated signal. They have a shell (GUI) in which you can also test circuits.
Offline Razonar
#5 Posted : 25 November 2024 19:23:12(UTC)
Razonar
Uruguay
Hi Viacheslav. As far as I could see, the plugin you created works very well, it just has some very minor details, like not recognizing either "u" or "μ" for micro. By the way, handling that is a configurable option in ltspice. So you shouldn't be the first one to have problems with that.
As for the analyses that spice# has, it's just a matter of discovering them, since the documentation they have is very little, and for example, I don't know what convention they followed to enumerate the nodes of the controlled sources. I took the one they use in the Qucs simulator, but there is no standard for that.
I saw the GUI for windows that you mention on github, except that they didn't compile it... or at least I didn't find it, only the source code.
on 25/11/2024(UTC)
Offline uni
#6 Posted : 25 November 2024 21:21:40(UTC)
uni
Similar project. I assembled it, but I haven't tried it in work.
NextGenSpice_20241125.zip (322kb) downloaded 5 time(s).
Links:
1. NextGenSpice/Program.cs
2. NextGenSpice/plot.ps1
on 26/11/2024(UTC)
Offline Razonar
#7 Posted : 01 December 2024 16:51:11(UTC)
Razonar
Uruguay
New version, more compatible with spice# sintaxis.
spice# and MNA v2.sm (637kb) downloaded 10 time(s).
spice# and MNA v2.pdf (1,673kb) downloaded 16 time(s).
on 01/12/2024(UTC)
Offline uni
#8 Posted : 10 December 2024 07:23:50(UTC)
uni
A task for implementation in the future:
Практический расчет параметров индуктивности
https://forum.cxem.net/i...араметров-индуктивности/
Offline uni
#9 Posted : 11 January 2025 22:41:49(UTC)
uni
SMath Studio compatibility Changes
Plugin updated.
Changes:
- Plugin adopted to a new SMath Studio Core infrastructure;
- Folders removed from the output artefacts.
thanks 4 users thanked uni for this useful post.
on 11/01/2025(UTC),  on 11/01/2025(UTC),  on 12/01/2025(UTC),  on 12/01/2025(UTC)
