Offline OchkovVF
#1 Posted : 01 December 2024 07:52:00(UTC)
OchkovVF
Was thanked: 42 time(s) in 39 post(s)
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (44kb) downloaded 14 time(s).
See too
https://en.smath.com/for...af_postst25212_Lens.aspx
Edited by user 01 December 2024 07:54:04(UTC)  | Reason: Not specified
Offline uni
#2 Posted : 02 December 2024 00:08:12(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
on 02/12/2024(UTC)
#3 Posted : 02 December 2024 01:52:45(UTC)
Was thanked: 1176 time(s) in 752 post(s)
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
2024-12-01 13_32_39-SMath Solver - [Lens-Mathcad-Block.sm_].png Lens-Mathcad-Block_Kr.sm (53kb) downloaded 6 time(s).
on 02/12/2024(UTC),  on 03/12/2024(UTC)
Offline OchkovVF
#4 Posted : 07 December 2024 19:02:58(UTC)
OchkovVF
Mathcad Prime
Edited by user 07 December 2024 19:09:50(UTC)  | Reason: Not specified
Offline Cornel
#5 Posted : 08 December 2024 07:05:34(UTC)
Cornel
Was thanked: 2 time(s) in 2 post(s)
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
Offline OchkovVF
#6 Posted : 08 December 2024 07:21:21(UTC)
OchkovVF
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
Offline uni
#7 Posted : 08 December 2024 08:29:44(UTC)
uni
What's wrong with the existing solvers?
Offline Cornel
#8 Posted : 08 December 2024 09:54:39(UTC)
Cornel
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
Edited by user 08 December 2024 09:59:54(UTC)  | Reason: Not specified
Offline Razonar
#9 Posted : 08 December 2024 11:04:39(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (309kb) downloaded 50 time(s).
RKA.pdf (932kb) downloaded 50 time(s).
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
Intel ODE Solver Library
DotNumerics
SADEL
Matlab C++ Math Library
OSLO
lsoda
GNU Scientific Library (GSL)
Edited by user 08 December 2024 11:13:42(UTC)  | Reason: Not specified
Offline Razonar
#10 Posted : 08 December 2024 14:58:47(UTC)
Razonar
Uruguay
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (180kb) downloaded 7 time(s).
I also use the Martin's setup for the plot.
Edited by user 08 December 2024 15:21:37(UTC)  | Reason: Not specified
Offline OchkovVF
#11 Posted : 09 December 2024 16:44:48(UTC)
OchkovVF
Offline Razonar
#12 Posted : 10 December 2024 10:11:05(UTC)
Razonar
Uruguay
Hi Valery. This is a way.
spherical aberration.sm (16kb) downloaded 9 time(s).
Edited by user 10 December 2024 11:54:16(UTC)  | Reason: Not specified
thanks 2 users thanked Razonar for this useful post.
on 10/12/2024(UTC),  on 10/12/2024(UTC)
Offline OchkovVF
#13 Posted : 10 December 2024 18:38:25(UTC)
OchkovVF
Thanks!
The last step
Offline Razonar
#14 Posted : 11 December 2024 03:21:41(UTC)
Razonar
Uruguay
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (27kb) downloaded 10 time(s).
thanks 3 users thanked Razonar for this useful post.
on 11/12/2024(UTC),  on 11/12/2024(UTC),  on 11/12/2024(UTC)
Offline oscampo
#15 Posted : 11 December 2024 03:35:39(UTC)
oscampo
Colombia
Was thanked: 119 time(s) in 81 post(s)
Very elegant solution
thanks 1 user thanked oscampo for this useful post.
on 11/12/2024(UTC)
#16 Posted : 11 December 2024 09:06:13(UTC)
Root-free version of the spherical lens
spherical aberration_Kr.sm (13kb) downloaded 7 time(s).
on 11/12/2024(UTC)
Offline Razonar
#17 Posted : 11 December 2024 12:22:06(UTC)
Razonar
Uruguay
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
on 11/12/2024(UTC)
Offline uni
#18 Posted : 12 December 2024 10:49:07(UTC)
uni
on 13/12/2024(UTC),  on 13/12/2024(UTC)
