Was thanked: 13 time(s) in 12 post(s)
Joined: 23/07/2013(UTC) Posts: 1,191  Was thanked: 544 time(s) in 366 post(s)
Unfortunately, it is compressed smath file. Unless we don't get uncompress algorithm, we can't work on this file.
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,639   Was thanked: 2011 time(s) in 679 post(s)
Hello. I was able to restore the file completely except 4 text titles of the areas (what actually caused an issue in your *.smz). dsm-VMR5.sm (133kb) downloaded 6 time(s).I think we need to disable functionality to save worksheets to .smz file format in the next release. It is not the first time issue appeared. Best regards. Edited by user 15 January 2025 11:54:59(UTC)
on 15/01/2025(UTC), on 15/01/2025(UTC), on 18/01/2025(UTC)
Originally Posted by: Andrey Ivashov  I think we need to disable functionality to save worksheets to .smz file format in the next release. It is not the first time issue appeared. Or maybe a rewrite for saving .sm files compressed as in .docx or .xlsx MS Office files are just xml wrappers for contents inside them. You can view files in them with extracting it as an archive. But I guess it will take some effort won't be compatible with old .smz files. Regards
Yes, we plan to move to Open Document Format but it will be another files extension.
As we discussed in the team a cheap alternative to .smz could be .sm.zip which is pretty easy to implement.
We'll think about it.
