10 Pages«<78910>
Offline Razonar
#161 Posted : 18 April 2023 08:22:20(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Draghilev's method for the Solve Block.
DraghilevSolveBlock.sm (550kb) downloaded 48 time(s).
DraghilevSolveBlock.pdf (1,462kb) downloaded 43 time(s).
on 18/04/2023(UTC)
Online uni
#162 Posted : 18 April 2023 09:26:27(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
I haven't done this yet because I want the user to be able to choose the type of lines. For all sides.
Edited by user 18 April 2023 16:13:20(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Online uni
#163 Posted : 18 April 2023 11:07:40(UTC)
uni
Unfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
Links:
1. Added support for parametric plot type
on 18/04/2023(UTC)
Online uni
#164 Posted : 29 April 2023 10:39:57(UTC)
uni
Theoretically, I can get data from any component. I can try to get the text from the text region.
on 29/04/2023(UTC)
Offline Razonar
#165 Posted : 29 April 2023 14:31:27(UTC)
Razonar
Uruguay
Originally Posted by: uni Go to Quoted Post
Theoretically, I can get data from any component. I can try to get the text from the text region....
Amazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know.
Online uni
#166 Posted : 29 April 2023 14:52:55(UTC)
uni
It's funny, I haven't tried it. I want to simplify the input of text programs. This is another way to extend the functionality of the program through third-party libraries.
A lot of useful libraries have been developed now. There is no point in repeating all this. It is necessary to create flexible interfaces for their integration and interaction with each other.
on 29/04/2023(UTC)
Offline Razonar
#167 Posted : 29 April 2023 15:39:33(UTC)
Razonar
Uruguay
... I want to simplify the input of text programs. ...
Yep. It would be very practical to have a tool to capture text to process it. I try to use description() function, but it has the drawback that it must be called at the worksheet level and it doesn't work well within the body of a function. Like in chess, RPN, Code or XYOptions.
Online uni
#168 Posted : 29 April 2023 19:00:47(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- MathcadBlock: added support for TextRegion.
Click to enlarge
maple-system-python-TextRegion.sm (6kb) downloaded 23 time(s).
on 30/04/2023(UTC),  on 30/04/2023(UTC)
Online uni
#169 Posted : 30 April 2023 19:14:56(UTC)
uni
Plugin updated.
Changes:
- MathcadBlock: added support for function definition.
Now the function definition can be written directly in the block.
Click to enlarge
maple-system-execute.sm (9kb) downloaded 33 time(s).
Memo Region also supported but it has not been updated for a long time, so some of its text functions do not work.
Edited by user 30 April 2023 19:43:28(UTC)  | Reason: Not specified
#170 Posted : 25 November 2023 14:25:40(UTC)
Was thanked: 1177 time(s) in 752 post(s)
Is there a chance to at least partially use units here? The values with units are disabled in the sheet, this is not visible in the png-file.
7-1.sm (30kb) downloaded 15 time(s).
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
on 26/11/2023(UTC)
Offline Razonar
#171 Posted : 25 November 2023 19:26:55(UTC)
Razonar
Uruguay
This is an option for having partial and full units support.
7-1-units.sm (36kb) downloaded 11 time(s).
Edited by user 25 November 2023 19:28:32(UTC)  | Reason: Not specified
thanks 2 users thanked Razonar for this useful post.
on 26/11/2023(UTC),  on 26/11/2023(UTC)
#172 Posted : 26 November 2023 01:44:24(UTC)
Alvaro, thanks for the hints.
By whatever reason, the unit of the independent variable is respected in rkfixed()=even though it is set to 1 locally. Whatever locally means if that happens in the last input parameter value.
7-1_units.sm (40kb) downloaded 11 time(s).
Offline Razonar
#173 Posted : 15 May 2024 10:41:22(UTC)
Razonar
Uruguay
Hi Viacheslav. It seems that there is some issue with Rkadapt and fixed that other solvers doesn't have.
dint - Rkadapt bug.sm (25kb) downloaded 9 time(s).
on 16/05/2024(UTC),  on 17/05/2024(UTC)
Online uni
#174 Posted : 17 May 2024 08:13:15(UTC)
uni
Indeed, this is strange, because the source code should be very similar for all solvers. I'll try to find the differences.
on 17/05/2024(UTC)
Offline Razonar
#175 Posted : 17 May 2024 19:38:02(UTC)
Razonar
Uruguay
Using ode solvers for evaluate double integrals.
dint-RK.sm (50kb) downloaded 24 time(s).
dint-RK.pdf (198kb) downloaded 29 time(s).
on 18/05/2024(UTC),  on 18/05/2024(UTC)
Offline Prmtv
#176 Posted : 25 July 2024 06:16:01(UTC)
Prmtv
Добрый вечер. Подскажите, как скачать этот плагин? Никак не могу это сделать, появляется ошибка при скачивании. Заранее благодарю!
Online uni
#177 Posted : 25 July 2024 08:16:54(UTC)
uni
Он должен загрузиться автоматически при выборе из галереи дополнений, либо при открытии любого документа, использующего плагин. Возможно это временные неполадки на сервере.
Offline Prmtv
#178 Posted : 26 July 2024 07:08:54(UTC)
Prmtv
В том и дело, что и скачать на сайте не получается, и при открытии установка плагина завершается ошибкой.
Online uni
#179 Posted : 05 October 2024 11:49:09(UTC)
uni
I select the type of bracket for different modes of operation of the block. There are problems with drawing the system sign.
Online uni
#180 Posted : 13 October 2024 20:54:02(UTC)
uni
I think it would be fun to add the ability to tell the component where to insert a set of expressions: as the first parameter, as the last parameter, as parameters, as parameters before specified, after specified.
Or to indicate where to place them.
Edited by user 13 October 2024 21:37:07(UTC)  | Reason: Not specified
10 Pages«<78910>
