4 Pages<1234>
#21 Posted : 26 October 2016 11:07:40(UTC)
Was thanked: 1378 time(s) in 902 post(s)
Originally Posted by: mikekaganski Go to Quoted Post
Also, no dynamic assistance is available. Though disabling the plugin doesn't help.
Dynamic assistance is enabled in the program's options?
on 26/10/2016(UTC)
Offline mikekaganski
#22 Posted : 26 October 2016 11:39:09(UTC)
mikekaganski
Clap Clap Clap Clapping
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 26/10/2016(UTC)
#23 Posted : 26 October 2016 14:14:41(UTC)
Was thanked: 983 time(s) in 811 post(s)
Hello Jean, according with CoolProp documentation "Q" stands for "Mass vapor quality", thus 1 is 1 mol/mol
Thanks Davide for "unitless Q" and the link to CoolProp Wrapper
on 26/10/2016(UTC)
#24 Posted : 26 October 2016 18:49:17(UTC)
Here's what I see:
Try now Good
on 26/10/2016(UTC),  on 27/10/2016(UTC)
#25 Posted : 26 October 2016 23:02:49(UTC)
mikekaganski
Thanks, Davide!
It's fixed indeed.
Best regards,
Mike Kaganski
#26 Posted : 07 January 2017 03:24:08(UTC)
Was thanked: 1167 time(s) in 746 post(s)
A german smath user contacted me and asked me to include the steamtable dll for EFI in the portable distribution. They weren't included in the recent update because this involves some additional config work and I assumed that the coolprop wrapper might be a replacement.
According to the mentioned user, the steamtables are of better accuracy than the coolprop functions. Thus I now updated the portable distribution.
The user also asked for speed of sound and isentropic exponent functions. Is there a way to help him?
#27 Posted : 08 January 2017 18:41:22(UTC)
"WASP" is freeware for 10 minutes use, unlimited sessions.
"WASP" from "Katmar". all properties are tabulated per T(°C) or P(abs).
#28 Posted : 08 January 2017 21:58:05(UTC)
As for the speed of sound can be accessed using "A" or "speed_of_sound"
For the isentropic functions I googled "isentropic coolprop" and there is something but it is not my field, maybe Mike can give some hints.
Offline Tim Gowing
#29 Posted : 17 May 2017 00:31:50(UTC)
Tim Gowing
Rank: Member
United Kingdom
Hello
On entering >>CoolProp_Props("D","T",298.15*K,"P",10*bar,"CO2")=<< I receive a message "K not defined;
Are the double quotes correct?
Tim
Edited by moderator 17 May 2017 01:33:10(UTC)  | Reason: added noparse BBcode
#30 Posted : 17 May 2017 01:35:12(UTC)
Hello Tim,
You missed the units character (apostrophe) before K and bar -> 'K, 'bar
CoolProp_Props("D","T",298.15*'K,"P",10*'bar,"CO2")
Offline Tim Gowing
#31 Posted : 17 May 2017 11:10:17(UTC)
Tim Gowing
Rank: Member
United Kingdom
Hello Davide,
Thank you for looking into my issue.
I had indeed overlooked the apostrophe, thank you.
I copy and pasted your coolprops statement into SMath but I don't get an answer, instead a red border around the statement.
I also typed the statement in from fresh and I get the same.
Is the ordinary >> = << used on a coolprops statement? Will the answer appear before units are applied to the result?
What is the most simple test to see coolprops working?
Tim
Offline Tim Gowing
#32 Posted : 17 May 2017 11:21:36(UTC)
Tim Gowing
Rank: Member
United Kingdom
This a screenshot of my coolprops entry, attached.Screenshot from 2017-05-17 09-14-49.png
Tim
p.s. I don't see how to paste the image; the Insert Image command asks for a URL.
#33 Posted : 17 May 2017 12:51:58(UTC)
What's the error message now?
Simplest way to check if it might works should be:
Code:
CoolProp_get_global_param_string("version")
Also, here there are 3 worksheets to run as test
Offline Aleksey
#34 Posted : 23 December 2017 03:39:02(UTC)
Aleksey
lastError="Error message couldn't be retrieved from CoolProp library (buffer size issue?); the second try returned: "
what's the problem?
Edited by moderator 23 December 2017 11:46:10(UTC)  | Reason: image attached (please use attach button instead of external services, if possible)
#35 Posted : 23 December 2017 11:47:39(UTC)
which versions of SMath and CoolProp plugin are you using?
#36 Posted : 25 December 2017 08:27:58(UTC)
Originally Posted by: Aleksey Go to Quoted Post
what's the problem?
There may be two issues:
1. WASP is awfully involved in Basic construction. I coded it in Mathcad 11
Get the Katmar WASP [very complete] free for 2 min session, unlimited sessions.
2. The published Basic is unitless, the CoolProp is unit based,
that is enough to freaked the codes. The Mathcad version from Valery was OK.
Sorry, can't help more.
Offline Aleksey
#37 Posted : 26 December 2017 05:59:35(UTC)
Aleksey
Error:
version SMath - 0.98(build 6484)
version CoolProp -
I'm try on the various Windows platforms (32/64):
good result on
Win10x64Pro, Win7x64Ultim
don't working on
Win10x86Pro, Win10x86Educ, Win7x86Pro
Best regards,
Aleksey
Edited by user 29 December 2017 05:32:09(UTC)  | Reason: Not specified
thanks 1 user thanked Aleksey for this useful post.
on 27/12/2017(UTC)
#38 Posted : 27 December 2017 09:43:32(UTC)
This is just a comment.
Assume my firm knows nothing about Smath and you are doing a project for us
and the project requires be tracable and you would use CoolProp-Wrapper.
If you can't prove it is certified, it won't pass QA.
CoolProp-Wrapper would be rejected [as simple as that].
IMHO, from this thread, CoolProp must be doctored regardless of the
Win version and/or Smath version.
#39 Posted : 27 December 2017 18:47:24(UTC)
don't working on
Thank you, reproduced. Something goes wrong with the wrapped 32 bit library (the coolprop dll returns both the correct result as well as an error code, hence the errors shown).
Edited by user 27 December 2017 18:52:07(UTC)  | Reason: Not specified
Offline dacts
#40 Posted : 17 January 2018 03:28:09(UTC)
dacts
Mexico
is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version"Wink" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
4 Pages<1234>
